Stone Coated Steel Installed During Winter Time - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 12-13-2011, 10:21 AM   #1
Rewards Points: 16
stone coated steel installed during winter time
What is your opinion professional roofers? we have to install our new roof between now until March or during the winter. There are not days above 40 degree between now and then. Is there any issue for this type of roof installed in the cold weather?
Thanks,
Paul
Paul.le is offline   Reply With Quote
Old 12-13-2011, 12:01 PM   #2
Gymschu's Avatar
Rewards Points: 466
Having done a roof (as a DIYer) in the winter time, well, let's just say, I wouldn't recommend it. Not only is it hard to install the roof itself, it's difficult to get up on the roof when you are battling frost, snow, wind, etc. Very dangerous.
Gymschu is online now   Reply With Quote
Old 12-13-2011, 01:10 PM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,818
Thanks,
Paul
None whatsoever. You are good to go.
One of the other benefits of steel vs. asphalt.
The Following User Says Thank You to Windows on Wash For This Useful Post:
Paul.le (12-13-2011)
Old 12-13-2011, 03:03 PM   #4
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
Steel is fine in winter. Just don't jam them together. Allow a little play so they don't 'heave' when they heat up in the summer.
tinner666 is offline   Reply With Quote
Old 12-13-2011, 03:12 PM   #5
+1
Give it a bit more of an expansion joint unless it is really warm.
Old 12-13-2011, 09:58 PM   #6
Rewards Points: 16
We are using contractor to install it. What kind of question or legal document that I should ask or know about before he start working on it. Thanks
Hiring drywall contractor for winter time work francisfellow Drywall & Plaster 6 12-15-2010 11:56 AM
installed new hot water tank and now we only get hot water if 2 sinks on at same time Terryh Plumbing 5 07-26-2010 04:54 PM
What did I do wrong the first time - I don't want repeats Snav General DIY Discussions 13 01-25-2010 03:26 PM
pouring deck piers in the winter time Knucklez Building & Construction 7 10-22-2009 08:31 AM
regular zinc coated steel hardware with ACQ treated lumber dumbunusedid Building & Construction 3 08-12-2008 08:20 PM
