Stick Building A 12x12 Shed Roof. - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 09-28-2011, 08:47 PM   #1
Stick building a 12x12 shed roof.
My husband and I are building a 12x12 shed. With a roof pitch of 4 12. We have all boards (rafters) cut out, we went to start haging them and 1 side of rafters don't reach our center beam board. We measured them all, what can we be doing wrong? One side does and one doesn't meet the center board. We measured the width across the top of shed wall and it is 144 inches wide. Thanks for any info.
toogiggly is offline   Reply With Quote
Old 09-28-2011, 08:48 PM   #2
Framing Contractor
Rewards Points: 112
Post a picture. Obviously if only one side reaches, you cut them wrong. YOu may be able to save the lumber by making an adjustment.
sixeightten is offline   Reply With Quote
Old 09-28-2011, 09:19 PM   #3
KemoSabe
loneframer's Avatar
My first guess is you have the ridge board too high. If you lower it with rafters attached to one side, by default, it will move closer to the rafters on the other side.
How did you establish the existing height of the ridge, as well as the length of the rafters?
Also, did you allow for the heel of the rafter? This is the distance from the seat cut of the birdsmouth to the top of the rafter, measured in a vertical line.
It's not that it took him an hour to make 100 bucks, it's that it didn't take you 10 hours to save 100 bucks.
loneframer is offline   Reply With Quote
Some more shed building questions. lukabrazi Building & Construction 10 02-05-2011 09:02 PM
Shed Roof Questions jobondur Roofing/Siding 1 10-04-2010 11:52 AM
The moving Ice Dams after using a roof rake ?? Canufixit Roofing/Siding 9 02-05-2009 08:33 PM
Morning Pilgrims! Greenhorn looking for answers! - Need help building a Shed bazzbozz Building & Construction 3 11-11-2008 09:36 AM
Venting a shed roof with 2/12 slope atulc Roofing/Siding 5 08-25-2006 08:28 AM
