Step Flashing: Where To Nail? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-16-2010, 12:25 AM   #1
Rewards Points: 18
Step Flashing: Where to Nail?
I've found different sites that tell me to nail the step flashing to the wall and others tell me to nail it to the roof. Which one is correct? Please explain.
Thanks,
Schmidt
Schmidty is offline   Reply With Quote
Old 07-16-2010, 06:44 AM   #2
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
Nail it to the roof - never to the wall.
The roof will likely need to be replaced before the siding. If it's nailed to the wall, you can't remove it. Nailed to the roof, you can slip the old out and new in without disturbing the siding.
seeyou is offline   Reply With Quote
Old 07-16-2010, 07:19 AM   #3
Residential Roofer
Slyfox's Avatar
If you nail your step flashing's to the roof your placing a fastener with in 2" too 5" of the wall every 5" too 9" inches all the way up the roof from the eave to the ridge.
If you fasten the steps into the wall you don't, or atleast shouldn't because your shingle fasteners should never be that close.
Most roofers "in snow/ice regions" run a strip of ice & water shield on the walls now a days, either under or over the step flashing's and some times both. In these cases, removing the step flashing's is going to be a problem no matter where you place your fasteners because the flashing's are going to stick to the ice & water shield and be quite an adventure to remove because of it.
I fasten my step flashing's to the wall, placing each fastener toward the top high point so that it will be completely covered by the next piece of flashing.
I always use thicker aluminum or copper, both those materials will out last the life span of the shingles. Installed properly they'll out last a couple life spans of shingles.
God Family Country Work Play
Facebook <> Twitter
Slyfox Exteriors Co.
Slyfox is offline   Reply With Quote
Old 07-16-2010, 07:21 AM   #4
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
Where do you nail your steps when flashing to masonry walls?
Old 07-16-2010, 07:29 AM   #5
Tom Struble's Avatar
Rewards Points: 2,002
i always heard it had to do with wall movement as to why you would nail to the deck,not sure about that
Tom Struble is offline   Reply With Quote
Old 07-16-2010, 07:30 AM   #6
Residential Roofer
Slyfox's Avatar
If the builders used a wooden ledger I'll fasten them to the wall, if they did not I'll fasten them to the roof, with the fasteners still placed in higher outside corner so the next piece of step covers it.
Facebook <> Twitter
Old 07-16-2010, 07:34 AM   #7
Residential Roofer
Slyfox's Avatar
If they are nailed to both the wall and deck I could see movement possibly being a problem, but just nailing to the wall should provide the same free movement as just nailing to the deck, I would think anyhow.
Facebook <> Twitter
Old 07-16-2010, 02:57 PM   #8
Rewards Points: 83
Perfect example of why you nail it to the roof and not the wall.
Tore off some T-Locs today, and the white step flashing was nailed to the wall. T-Locs and Certainteed Landmarks have a major difference in exposure.
Because I was unable to adjust the step flashing due to it being nailed to the wall, there are now some white pieces of step flashing exposed on my Moire Black roof. Had those steps been nailed to the roof, I would have been able to adjust them accordingly.
Luckily it's a 4/12 and you can't see the roof/wall join from the ground.
bcdemon is offline   Reply With Quote
The Following User Says Thank You to bcdemon For This Useful Post:
seeyou (07-16-2010)
Old 07-16-2010, 08:02 PM   #9
Residential Roofer
Slyfox's Avatar
I have run into that problem several times, if you run a double course a couple times while your working your way up the wall you can finish with out any exposed metal and do so with out sacrificing quality.
It's no more difficult than dealing with the few pieces that the J channel nails hit, here and there.
Facebook <> Twitter
The Following User Says Thank You to Slyfox For This Useful Post:
Schmidty (07-17-2010)
What length step flashing is correct? Ohming Roofing/Siding 17 08-07-2009 01:02 PM
Unfinished step around wood laminate floors markq Flooring 7 07-17-2009 08:19 PM
Need roofing tips! dc4nomore Roofing/Siding 114 07-03-2009 08:01 AM
Do architectural shingles really work with step flashing? Malcolm Roofing/Siding 7 05-02-2008 11:31 PM
step flashing Clutchcargo Roofing/Siding 4 09-02-2007 02:39 PM
