Step Flashing Question - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-29-2012, 07:34 PM   #1
cdm
Hey Everyone,
I am not sure if this is a siding issue or flashing issue. I am getting water running down behind my siding where the addition butts up to the original home. I attached a photo of where the water is coming from under the siding as well as how the roof looks. I initially extended the downspout to try and divert the water away from the corner but its still happening. Any help or suggestions would be appreciated. From my research it looks like I need a a step flashing diverter but I wasn't sure if this is correct or how to install.
CDM
cdm is offline   Reply With Quote
Old 07-29-2012, 07:54 PM   #2
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
It's called a kickout. It has to go behind the siding and behind/under the first piece of step flashing to work. http://www.nachi.org/kick-out-flashing.htm
tinner666 is offline   Reply With Quote
Old 07-29-2012, 07:57 PM   #3
Remodeling Contractor
oldfrt's Avatar
Rewards Points: 186
Both the step flashing and J on the roof should direct
water over the face of the siding.
oldfrt is offline   Reply With Quote
Old 07-29-2012, 08:40 PM   #4
cdm
So do you both agree that the reason for the water getting behind the siding is due to the lack of a kick out. Is it possible to just remove a few pieces of the siding to be able to install one?
Thank you for the photo by the way.
Old 07-29-2012, 08:53 PM   #5
oldfrt's Avatar
Rewards Points: 186
It's probably the most likely reason and remedy.
The siding can be" unlocked" near the flashing and properly repaired.
Any local building supply outlet should have the tool designed for this.
While you have the siding pulled out,check to make sure the house wrap
extends over the top of the step flashing.
Old 07-30-2012, 03:35 AM   #6
Rewards Points: 324
Here's how we do it, a purpose made pvc kickout unit. This wall is ready for new siding. (the wood battens on the outside of the house wrap is to create a drained/vented cavity behind the siding, which is a requirement here nowadays on many homes)
mgp roofing is offline   Reply With Quote
Old 07-30-2012, 07:43 AM   #7
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 3,286
Siding can be unlocked and the kick out installed.
No special tools are required to unlock the siding but the unzippers do make it easier.
Old 07-30-2012, 10:12 AM   #8
cdm
Great thanks guys for the quick response. I will give it a try, I already have one of those siding tools, had to remove alot of siding to replace a sliding glass door that also leaked.
Old 07-31-2012, 08:02 AM   #9
Roofing Contractor
My sider likes to use the little mini wonder bars to pop off plastic siding.
We've installed many kick outs diverters without taking the plastic siding off the home. You first put the kick out were you need it and make a line were it goes against the siding. Then you use either a straight edge or a good pair of tin snips and cut up from the bottom. Some times you also have to cut the j channel sometimes you don't. Once it's cut you then have to push the new piece of flashing up under the bottom most shingle tin (step flashing). To finish it off you put some good quality caulk on the back side of the diverter to siding spot.
Good Luck!
BTW, kick outs or diverter flashings have been code here in MN for several years.
dougger222 is offline   Reply With Quote
Flashing replacement question daluu Roofing/Siding 16 01-26-2012 08:36 PM
Question about this wind-damaged flashing: kazyctn Roofing/Siding 4 01-13-2012 07:37 PM
Install Flashing onto existing deck ledger, stucco home Ameekins Building & Construction 1 09-15-2010 05:51 PM
Skylight flashing Swamp Yankee Roofing/Siding 1 08-13-2010 10:48 AM
How Should I Frame this Single 10' Wide Step? Chris' Place Remodeling 4 04-02-2008 09:31 PM
