Step Flashing Confirmation - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 05-01-2014, 10:09 PM   #1
Rewards Points: 16
Step flashing confirmation
I have several versions of instructions from online sources on installing step flashing and nobody (including FEMA) mentions sealant or roofing cement. I just wanted to confirm with real people that for step flashing at a roof-wall intersection, there does not need to be roofing cement or sealant between, under, in, on, or over the flashing pieces, or between the edges of the shingles and the flashing.
Is this correct?
suobs is offline   Reply With Quote
Old 05-01-2014, 10:19 PM   #2
Rob
Robpo's Avatar
Rewards Points: 826
You don't need caulk if the siding goes over the flashing.
Robpo is offline   Reply With Quote
Old 05-02-2014, 05:34 AM   #3
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
Yes, it's correct. Be sure to get the right size that overlaps each course 2"-3".
Cement and caulk aren't used at any wall intersection, btw.
tinner666 is offline   Reply With Quote
The Following User Says Thank You to tinner666 For This Useful Post:
Windows on Wash (05-02-2014)
Wood Chimney Flashing Billdonne Roofing/Siding 2 03-06-2013 05:13 PM
flashing a vinyl window into stucco yhfwd05 Windows and Doors 0 01-28-2013 07:51 PM
Need roofing tips! dc4nomore Roofing/Siding 114 07-03-2009 07:01 AM
tiling outdoor step kristinmcdonald Tiling, ceramics, marble 6 06-08-2009 11:02 PM
Step footing has gaps joshoc Building & Construction 4 05-06-2009 04:11 PM
