Step Flashing - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 09-01-2007, 04:49 PM   #1
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,374
step flashing
I'm putting shingles down and have a question about step flashing. Do you nail through the shingle and step flashing or is it better to just use adhesive over the step flashing?
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 09-01-2007, 07:00 PM   #2
I have gas!
OK, I figured it out. The next piece covers the nail in the previous piece of step.
Another thing I figured out... I hate roofing.
Old 09-01-2007, 11:23 PM   #3
the roofing god's Avatar
Send a message via MSN to the roofing god
put nail in top 2" of step flashing only,keep shingle nails 4"away from step flashing,step flashing starts where shingle exposure ends,except the 1st 1 or 2 if the wall ends up down at the fascia
the roofing god is offline   Reply With Quote
Old 09-02-2007, 07:16 AM   #4
I have gas!
I searched the internet and found several different approaches to laying out step flashing. I kept the nails in the same line as the shingles and kept the edge of the step on the same line as the edge of the shingles. The next piece of step covered the nail of the previous step. I'm only 5 courses into this job. Did I screw up?
I thought that if no water can enter under the shingles with only 1/2 - 3/4" covering, why would the flashing be different.
I'm only 5 courses into it, should I strip out the flashing and reattach?
What are the chances of leaking if I left this portion as is and continued correctly.
I'm worried that pulling up would add more holes through the underlayment and be bigger cause for a potential leak.
Old 09-02-2007, 01:39 PM   #5
THERE SHOULD BE 2" HEADLAP PER EACH STEP,SOUNDS LIKE YOU`RE USING METRIC SHINGLES W/5X7 FLASHING(STANDARD SIZE),RIP IT OUT AND GET 5"X8" STEP TO FLASH IT PROPERLY-1ST PIECE BETWEEN STARTER AND 1ST COURSE,THEN EACH SUCCESSIVE ONE BOTTOM SET TO EDGE OF SHINGLE EXPOSURE(SO IT DOESN`T SHOW)-THE 8" GOES ALONG THE HEIGHT OF THE SHINGLE,THE 5"IS BENT IN THE MIDDLE SO HALF IS ON ROOF,HALF IS ON WALL
Do architectural shingles really work with step flashing? Malcolm Roofing/Siding 7 05-02-2008 10:31 PM
Plumbing vent flashing FatAugie Roofing/Siding 7 08-24-2007 08:30 PM
Roof to Sidewall Flashing handyman923 Roofing/Siding 1 09-13-2006 04:02 PM
Step by step Trishl Flooring 2 05-12-2006 10:03 PM
Flashing problems Slave Building & Construction 3 11-16-2005 03:56 PM
