Steel Siding Value? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 04-26-2014, 10:13 AM   #1
Rewards Points: 768
Steel siding value?
We've got about 30 square of steel siding from the early 90s we'll be replacing. Is it worth anything if I were to take it to a scrap yard? Otherwise I'd need to rent a dumpster...just trying to plan.
cibula11 is offline   Reply With Quote
Old 04-26-2014, 10:22 AM   #2
Civil Engineer
Rewards Points: 4,514
Should have scrap value as steel. Call the yard ahead to make sure they take siding, they should give you the unit price for scrap when you call.
The Following User Says Thank You to Daniel Holzman For This Useful Post:
Windows on Wash (04-27-2014)
Old 04-26-2014, 11:11 AM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 334
Ayuh,.... 'bout $.05 to $.08@lbs.....
Bondo is online now   Reply With Quote
The Following User Says Thank You to Bondo For This Useful Post:
Siding Options to repair clapboard type siding 30Five Carpentry 7 12-29-2011 02:42 PM
Painting steel corragated siding carbine Painting 1 05-29-2010 07:07 AM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
