Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 09-04-2012, 11:26 PM   #1
Steel roofing
Does Michigan codes requirer a Ice sheild under a steel roof. it's a residental roof. the steel panels are one lenght
Dale JUrecki is offline   Reply With Quote
Old 09-05-2012, 01:10 AM   #2
Steel roofing
No idea what that states code is but metal roof does not even need sheathing under it so what good would storm and ice shield do?
Why are you asking?
Look around at some of the metal roofing sites and see what they require under the roofing.
Most suggest skip sheeting.
Some say just use 1 X 6's.
Old 09-05-2012, 07:17 AM   #3
Exterior Construction
Windows on Wash's Avatar
Steel roofing
Many codes don't separate out the requirements for steel vs. traditional asphalt.
If it is one panel, you are correct that it will be redundant but potentially still code mandated.
Choosing The "Right" Roofing Contractor, How To Evaluate Who Is Right! Ed the Roofer Roofing 27 04-25-2013 06:10 AM
Manufacture History Roofmaster417 Roofing 6 02-23-2012 03:40 AM
Roofing Material History Roofmaster417 Roofing 4 09-08-2011 05:49 PM
Roll Roofing Edge Leak toolboxone Roofing 5 10-07-2009 07:09 AM
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 05:24 PM
