Starting New Roof - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 09-01-2007, 09:35 AM   #1
Starting new roof
I am going to attempt to roof the top of my garage this weekend. I have done about 5 roofs but this is the first one by myself. I plan on taking off the old roof (there is only one layer) but I want to get down to the decking to replace a section that I know is bad. My question is: Can I do this without taking off the drip edge and rake edge and gutter (It is all still in good shape) and if I can, is it okay to put the I&W and felt paper on top of the drip and rake edges ?
Thank You.
dolppl is offline   Reply With Quote
Old 09-01-2007, 10:04 AM   #2
What part of the world are you in?
You can leave the drip edge, but know you are about to install a system that you shouldn't have to mess with for 20-25 years or better. Nail holding strength on drip edge is not getting better with age.
At eave in FL go over drip edge with felt or trowel roofing cement D-edge to felt is code. At Rake better practice is to D-edge over felt and trowel roof cement. I have my people cement twice once for the inspector and once to help hold the shingle edge down. (this helps rake edge in high winds)
Lots of peel & stick out there today. Much better than Felt if project is not real large, it can be affordable and worry free.
good luck
Big Bob is offline   Reply With Quote
Old 09-01-2007, 09:59 PM   #3
FatAugie's Avatar
Talking
How much is drip edge? $5 for a 10' section? Rip that old crap out and put in new, you'll be glad you did. Much less screwing around trying to save it and yes, you should put the felt under the drip at the rake edges from everything I've seen.
Good luck!
FatAugie is offline   Reply With Quote
Old 09-02-2007, 12:20 AM   #4
the roofing god's Avatar
Send a message via MSN to the roofing god
about 3$,stick ice shield to fascia edge ,remove rake metal put felt then put it back over,or replace
the roofing god is offline   Reply With Quote
Old 09-02-2007, 09:18 AM   #5
FatAugie's Avatar
When I tried to remove drip edge I just nailed in, I ended up ripping out the nail hole, leaving the nail behind. For $3 a piece, why would you want to screw around with old?
Old 09-02-2007, 09:19 AM   #6
MJW
Take everything off the roof. Put new drip edge on the bottom edge, then I&W on top of that, then tarpaper the rest of the way up. On the rakes, put the drip edge on top of the felt. Some of the old-timers still put the drip edge on top of the I&W and that's wrong.
MJW is offline   Reply With Quote
Old 09-02-2007, 02:29 PM   #7
I would use new drip edge ,on the bottoms,I USE 3X3 AT THE BOTTOM SO THE METAL GOES BEHIND ANY GUTTERING,then drip edge goes over at rake(side) eaves-if you have a box of weather watch ,it gives these instructions on the box-all my stuff is accurate w/the times
Please help with the design of this roof jaymay75 Building & Construction 1 05-06-2008 10:44 AM
leaking tar and gravel roof meleis Roofing/Siding 9 01-05-2008 11:27 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 07:17 AM
Venting a shed roof with 2/12 slope atulc Roofing/Siding 5 08-25-2006 08:28 AM
flat roof leak snikda9 Roofing/Siding 16 01-26-2006 05:25 PM
