Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 11-22-2009, 10:16 PM   #1
Starter strips, which way up?
Hi all,
With regard to asphalt shingles, which way up should the starter strips go? Adhesive strip face up or down? And at the edge, correct? and do they need to be lapped from bottom to top?
Thanks!
zantar is offline   Reply With Quote
Old 11-23-2009, 12:16 AM   #2
hello yes the starter strip adhesive facing down. then overhang the strip 1/4 INCH past the drip edge. then your 1st roll of shingles even with the starter strips edge. good luck on your roofing
repair24/7 is offline   Reply With Quote
Old 11-23-2009, 06:50 AM   #3
Residential Roofer
Slyfox's Avatar
Starter strips do not overlap, they but up to one another.
They are run across the eaves and up the rakes, not the ridge.
The sealant strip will face up so it seals to the underneath portion of the shingle covering it.
God Family Country Work Play
Slyfox is offline   Reply With Quote
Old 11-23-2009, 06:58 AM   #4
ArmchairDIY's Avatar
yep, what he said.
"It looked good on paper, but paper is funny that way"
Time to Get Up Out of Your Chair and Do it Yourself!
ArmchairDIY is offline   Reply With Quote
Old 11-23-2009, 08:47 AM   #5
MJW
1/2" overhang, and what Sly said.
Some starter strip rolls from the big box rip off stores have a peal off adhesive side that is supposed to stick to the roof, so it does go down. That would have come with instructions though.
After that, the rest of the shingles must be put on upside down in order to work correctly. Better to start at the peak also.
MJW is offline   Reply With Quote
Old 11-23-2009, 09:03 AM   #6
Xtreme DIY'r
This is the 1st I have heard of instllaing start strips along the rake ?
GAF doesn't include it in their install directions
Is this just a better way to do it based on experience, better wind resistance...or ?
AH...just found it under their improved wind performance video
Old 11-23-2009, 10:11 AM   #7
SlyFox, while we got you on the air here,,,,,,,,,, today I learned the adhesive side goes up on starter , thank you, another question, does it hurt to use regular shingle for the starter and just assuming the shingle would face up so that the slots are covered by first row. And, thanks for all your input on this forum, I appreciate it.
LIVING THE DREAM
DUDE! is offline   Reply With Quote
Old 11-23-2009, 10:49 AM   #8
Ahem.. Well guess what guys.. I already installed the starter strips with adhesive face down.. oops.. I used part of the shingle, not a ready made "starter strip". I assumed that I would install it with the granules up, therefore the adhesive was down. Later I saw some youtube video saying that was like the worst thing you could possibly do So should I be concerned? Can I put some glue between it and the first run? Or not bother? If glue down, what is the best stuff? Keep in mind I'm in Toronto, if that matters.
Thanks!
Old 11-23-2009, 11:51 AM   #9
Xtreme DIY'r
The older shingles I have the tar adhesive line is on the same side as the granules
Some of the newer ones I have seen the tar adhesive line on the opposite side from the granules
Have you already run a bunch of rows of shingles ?
I'm sure you could put tar between the 1st course & the starter strip
I'm just not sure which product to use, and it effectiveness VS the factory stuff
Old 11-23-2009, 12:02 PM   #10
The roof is done, other than the ridge vent. So it does seem that there are several different places that manufacturers run shingle adhesive. Mine was on the bottom at one edge (not the middle). I'm using iko cambridge. So I think for me the question is what type of caulk/adhesive if necessary.
Thanks!
Old 11-23-2009, 12:39 PM   #11
I would use a plastic cement.Use 3 or 4 dime size blobs under each shingle.Too much could cause blistering.
johnk is offline   Reply With Quote
Old 11-23-2009, 02:02 PM   #12
Gotcha. Is Mono 555 a "plastic cement"? I'm needing more info on different kinds of caulks/adhesives I think..
How close to the edge?
Old 11-23-2009, 02:18 PM   #13
MJW
I wouldn't worry about it too much. The granule side of the starter should be up. Usually that is the side that the tar is on. Never used IKO, so not sure, but if the shingles have tar on the back side like the newer shingles (last 10 years), it will adhere to the starter.
Like I said before, some "stick on" starter rolls have adhesive on the back to stick to the roof. This is usually lower end box store stuff.
Starter up the rake make a much nicer, straighter edge, plus more wind resistant.
Using a 3 tab for a starter is fine also. Did it on hundreds of houses before the manufacturers "woke up" and started cutting down their 2nds to be sold as starters. Now they sell break apart starters.
Old 11-23-2009, 06:26 PM   #14
Pro Slate Roofer
tinner666's Avatar
Cut the tabs off the regular shingle. This leaves you a 7" starter strip. Then install them with whatever overhang you want, I prefer 1 1/2", and nail on the bottom 1" of the roof deck. This puts the nails right at the eave, and the sealer strip too.
Frank
tinner666 is offline   Reply With Quote
The Hows and Whys of Furring Strips. Part-1 Willie T How To Guides 12 03-01-2013 03:58 PM
Expand/Contract: Glue & screw 7" x 3/4" OSB strips on top of 3/4 plywood subfloor ? iMisspell General Discussion 8 05-11-2009 08:09 PM
scf starter wireing help needed rummins Electrical 6 06-20-2008 05:41 PM
Need help with installing carpet tack strips proofer Flooring 5 05-24-2008 06:51 PM
No starter strips fishwi Roofing 4 10-12-2005 10:32 AM
