Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 08-31-2012, 09:18 PM   #1
Solutions (handyman)
Starter strip over weather guard?
Conflicting points of view. If weather guard (ice shield) is in place, does a starter strip still have to be added prior to asphalt shingles being installed?
Thanks.
Mark Harvey is offline   Reply With Quote
Old 08-31-2012, 09:36 PM   #2
Yes you still use a starter strip.
Mark Harvey (09-01-2012)
Old 09-01-2012, 08:47 AM   #3
Doing This Way Too Long
Yes it does
OldNBroken is offline   Reply With Quote
The Following User Says Thank You to OldNBroken For This Useful Post:
Old 09-01-2012, 10:58 PM   #4
Yuuuuup- this is covered in the install guide of every shingle manuf in existence. Just google the shingle manufacturer and installation manual and you will get what you need.
RJM Build is offline   Reply With Quote
Old 09-04-2012, 02:29 AM   #5
It does, although a lot of roofers here don't, instead relying on the ice/water to act as the starter. In fact one supplier here has it in their install instructions! I always install the starter strips, they only cost $30-$60 on the average roof.
mgp roofing is offline   Reply With Quote
Old 09-04-2012, 08:39 AM   #6
It's usually a better idea to follow the Manufacturers instructions before the Suppliers instructions. And every manufacturer requires the use of starters.
bcdemon is offline   Reply With Quote
Old 09-04-2012, 09:25 AM   #7
I have NEVER EVER used ice and water shield as a starter course, and have no idea why a supply house would ever suggest that. Even when I worked for the worst of the worst hack shops where every corner that could be cut would be we would turn a 3-tab shingle backwards and use that. the first course needs something with some meat to adhere to. What state are you in?
The Hows and Whys of Furring Strips. Part-1 Willie T How To Guides 12 03-01-2013 03:58 PM
Forgot starter strip when shingling marykirk Roofing 5 05-31-2012 11:05 AM
No starter strip used on shed roof install? waterskier_erie Roofing 4 10-31-2011 09:25 PM
siding starter strip cbzdel General Discussion 2 08-03-2011 04:49 PM
No starter strip!?! hockeyhead Roofing 10 09-17-2005 12:54 PM
