Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 10-14-2010, 02:48 PM   #1
Question
starter strip
We bought a house that has a new roof on it, but we had to have eavestroughing put on the house. the man doing it said we have no starter strip on the roofing and the new roof won't last 10 years because of it. the new shingles are 35 years shingles. is this true?
Pastor is offline   Reply With Quote
Old 10-14-2010, 04:25 PM   #2
Residential Roofer
Slyfox's Avatar
starter strip
No starter/soldier course on the eaves will develop leak issues, eventually,
none on the gables won't/shouldn't be a problem unless they didn't install a proper overhang.
A couple pics would be helpful, it's not to often you see shingles ran with out starters on the eaves, I have only seen it done twice in the 30 years in the business.
God Family Country Work Play
Slyfox is offline   Reply With Quote
The Following User Says Thank You to Slyfox For This Useful Post:
Pastor (10-18-2010)
Old 10-14-2010, 04:50 PM   #3
Question
starter strip
the gables does have shingles put upside down along the edge. The length of the roof has an ice shield put down, but no starter strip on top of the ice shield before the shingles. There is an over hang of about 1-2 ins on all the roof.
Old 10-17-2010, 04:40 PM   #4
RoofDiagnostics's Avatar
starter strip
are the shingles 3-tab or architectural shingles? if the shingles are 3-tab, the probability of water infiltration would be much greater then if it is an architectural shingle.
Next, how steep is your roof? If the roof is very steep (8-or-9/12 pitch) you would be far less likely to have infiltration issues.
The presence of ice/water shield is a big help- ice and water is very effective at the eave perimeter.
RoofDiagnostics is offline   Reply With Quote
The Following User Says Thank You to RoofDiagnostics For This Useful Post:
Pastor (10-18-2010)
Old 10-18-2010, 04:22 PM   #5
Super Moderator
starter strip
I run into a true case of no Starter Course of shingles on at least 1-2 homes per year, even including the older method of utilizing flipped upside down 3-tabs for that purpose.
If in fact there is a course of upside down 3-tabs used as a starter course, then the new roof only has to be spaced properly during it's initial alignment, so as to not align vertically, gap from the butt ends of the new shingles on top of the butt end gaps of the upside down 3-tab shingles.
Ed
Stay Tuned For Our New Informative And Helpful Web Site, Coming Soon
Ed the Roofer is offline   Reply With Quote
Old 11-01-2010, 09:13 PM   #6
starter strip
Sounds Like hes scaming you. Get another opinion.
Denzo is offline   Reply With Quote
Old 11-01-2010, 10:59 PM   #7
SteveTheRoofer's Avatar
starter strip
If the gutter installer is not himself a professional roofer I would definitely get another opinion from a reputable roofing company in your area. Also, this something that can be repaired.
SteveTheRoofer is offline   Reply With Quote
The Hows and Whys of Furring Strips. Part-1 Willie T How To Guides 12 03-01-2013 03:58 PM
Goodman GPH1336H21AA heat strip connection jrajra HVAC 2 09-02-2010 05:52 PM
Vinyl siding - Starter strip height bacdef Building & Construction 6 08-06-2008 10:53 PM
Sizing Supplemental Strip Heaters on HP System hennyh HVAC 2 01-03-2007 12:28 PM
No starter strip!?! hockeyhead Roofing 10 09-17-2005 12:54 PM
