Starter Shingle Under The Rake Drip Edge - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 12-14-2011, 08:54 PM   #1
Should the starter shingles go under the RAKE drip edge? On this web site it clearly said to put the starter shingle over the eave drip edge and under the rake drip edge.
http://www.doityourself.com/stry/roofingshingles
Also, I have a ridge without a ridge vent. When I reach the ridge, should I let the upper part of the shingles wrap over the ridge from each side?
Phil
Phila is offline   Reply With Quote
Old 12-14-2011, 09:04 PM   #2
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Over the metal. Don't run the last course of shingles too far over that the ridge cap doesn't cover them (4-6"). You may or may not have to rip some inches off.
(the bundles have instructions on the package).
Sent from a Samsung Galaxy S2
titanoman is offline   Reply With Quote
The Following User Says Thank You to titanoman For This Useful Post:
Phila (12-15-2011)
Old 12-15-2011, 06:10 AM   #3
Residential Roofer
Slyfox's Avatar
I find it hard to believe that article was written by a roofer Phila,
not sure I would abide by anything that guy/gal wrote.
God Family Country Work Play
Facebook <> Twitter
Slyfox Exteriors Co.
Slyfox is offline   Reply With Quote
The Following User Says Thank You to Slyfox For This Useful Post:
Phila (12-15-2011)
Old 12-15-2011, 08:09 AM   #4
RFN-4A-LVN
Roofmaster417's Avatar
Ditto.,I alway's and alway's have installed starters on the entire perimeter of the roof.Some think its a waste of time and materials but IMO depending on climate it can contribute to rakeline damage.
Roofmaster417 is offline   Reply With Quote
The Following User Says Thank You to Roofmaster417 For This Useful Post:
Phila (12-15-2011)
Old 12-15-2011, 10:35 AM   #5
Disabled wood vet
titanoman's Avatar
I didn't read the article, but I know the main purpose of starter shingles is so the leading edge of the main course will be glued down and not flopping in the breeze, which would make rake starters unnecessary, though I run starters anyway.
Old 12-15-2011, 12:20 PM   #6
RFN-4A-LVN
Originally Posted by titanoman View Post
but I know the main purpose of starter shingles is so the leading edge of the main course will be glued down and not flopping in the breeze.
Partially correct.,But the starters primary function along the gutterline is to offset the leading course of shingles.The starter will eliminate water seepage between the seams leading to rotted decking,fascia,rafter tails,etc.
Old 12-15-2011, 12:36 PM   #7
Disabled wood vet
titanoman's Avatar
Yes, especially 3-tab. The purpose for the starters is exactly for what we both said.
Old 12-15-2011, 01:32 PM   #8
MJW
We run starters or bleeders on all roof edges. Makes a cleaner edge and the sealing strip does help hold them a little better up the rakes. From underneath it looks much better too, unless you are like some of the larger companies around here who just cut off the top of the laminates and use them for up the rake. The plastic strips show and it looks terrible, plus no sealing strip.
MJW is offline   Reply With Quote
Old 12-15-2011, 08:17 PM   #9
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,294
You run starters when you use 3-tabs?
Old 12-15-2011, 08:27 PM   #10
Disabled wood vet
titanoman's Avatar
Of course.
Old 12-15-2011, 10:59 PM   #11
Wink
Thanks to all of you for sharing your insight.
Old 12-16-2011, 07:03 AM   #12
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
What you don't want is for the bleeder to be the out edge for the neat look. The shingle tops catch the water direct it across the roof. This is how to do it incorrectly.
Starter Shingle Under The Rake Drip Edge-shingle-gable-soaker.jpg   Starter Shingle Under The Rake Drip Edge-shingle-gable-soaker-2-.jpg   Starter Shingle Under The Rake Drip Edge-shingle-gable-soaker-3-.jpg
tinner666 is offline   Reply With Quote
The Following User Says Thank You to tinner666 For This Useful Post:
rossfingal (12-16-2011)
Old 12-16-2011, 07:11 AM   #13
Pro Slate Roofer
tinner666's Avatar
I can't find the pix showing the correct way. I have them somewhere.
You cut the 3-tabs and a bit more off, then set the shingle back at the edge with the sealer strip on the rake, and nailed every 6" along the rake. The shingles then are run and cut about 1/2" past the soaker so water never lands on the soaker.
Old 12-16-2011, 11:39 AM   #14
Of course.
I was asking him if he ran starters of just another 3-tab...not that there wasn't another layer.
rake drip edge diyroofer Roofing/Siding 6 09-07-2011 10:49 PM
Drip edge under felt Jeoroc24 Roofing/Siding 1 09-07-2011 10:40 PM
Vented drip edge - starter vent jttucker3 Roofing/Siding 1 11-20-2010 07:50 PM
roof drip edge billygale Roofing/Siding 9 10-24-2010 02:19 PM
Shingle Installation with F5S Standard Drip Edge ShortEdged Roofing/Siding 32 02-15-2008 02:10 PM
