Starter Course & Roofing Cement - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 10-07-2009, 12:18 AM   #1
Starter course & roofing cement
We're building our own house, in the tropics (read: hurricane belt) and getting ready to shingle our 4/12 hip roof. I've read that some recommend smearing the starter course underside & first course underside with roofing cement. Others say dallops on both, others say nails only is fine. As high winds here are a major concern, I'd appreciate any input. We're using GAF Prestique40 shingles over 30# felt with Grace W/I at the hips & ridge. Many Thanks.
caybound is offline   Reply With Quote
Old 10-07-2009, 05:48 AM   #2
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
Buy 25 year 3-tab shingles and cut 4 1/2" off the tabs. Install dripedge. Hang the shingles about 1" past the DE. Nail the shingles as low as possible. This will put 2 sealing strips right on the bottom of the roof.
I assume you're installing I&W before the DE? And wrapped down about an inch?
tinner666 is offline   Reply With Quote
Old 10-07-2009, 06:32 AM   #3
Already bought the Prestique40 shingles. I&W on hips & ridge only as, um, ice is not a problem here. DE is "T" type. We're concerned about too much overhang as 1) we get HEAVY rains and often see water overshooting people's gutters (and we catch rainwater for the cistern) & 2) it's always the first course that gets ripped off in tropical storms/hurricanes, which then gives the wind "a way in".
We've been in the Tropics for 11 years and have seen many roof failures. We're happy to put in any xtra work that might keep our shingles on during the inevitable blow. Every year will bring high winds, even w/o a hurricane, which we know weakens the shingles bit by bit.
Thanks for your input - much appreciated.
Old 10-07-2009, 10:52 AM   #4
Commercial Roofing
AaronB's Avatar
I think if you follow the Florida roofing code, you will be well off.
www.roseroofing.net/ Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Old 10-07-2009, 07:16 PM   #5
Honestly, we consider "code" to be the minumum. We know the Dade County specs but were hoping to get some opinions from the guys who REALLY know what happens out there. I'll take the opinion of a guy who sees roof failures, and what causes them, year after year over an an engineer with computer models.
Old 10-07-2009, 07:44 PM   #6
Commercial Roofing
AaronB's Avatar
Ok, then cement the starter course down.
Choosing The "Right" Roofing Contractor, How To Evaluate Who Is Right! Ed the Roofer Roofing/Siding 27 04-25-2013 05:10 AM
gravel tar roof repairing mazizbit Roofing/Siding 7 04-09-2012 09:52 AM
Roll Roofing Edge Leak toolboxone Roofing/Siding 5 10-07-2009 06:09 AM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
