Standing Seam Tin Roof - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-07-2012, 08:58 PM   #1
Standing seam tin roof
I have a standing seam tin roof, which was professionally installed 15 years ago. The recent storms in Virginia have loosened one section of the roof. As I look from inside the attic I can see where the roof has lifted about an inch from the boards to which they were nailed. From the outside, no nails or screws are visible. Clips were used, which were then covered when the seams were crimped. Also from the outside, some of the paper used for condensation has slipped out from the bottom edge of the tin and is wedged in my gutter. The whole area is about 10-15 feet from the gable and down the full length if the roof - maybe 20 ft (the 2nd floor is 30x32 w/a 5/12 pitch). So, my question is - realizing just pounding the nails in would be insufficient and would most likely cause damage to the tin - could metal to wood collated screws with washers be used? I'm not fond of punching holes in my roof, but I do not have the skill set to remove the roof panels, replace, and recrimp them. Thoughts?
jfwiv is offline   Reply With Quote
Old 07-07-2012, 09:00 PM   #2
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
How loose is the section? The paper can just be pulled out and tossed, btw.
tinner666 is offline   Reply With Quote
Old 07-07-2012, 09:01 PM   #3
Pro Slate Roofer
tinner666's Avatar
Middle of a panel? Edge of a panel? Eave? Rake?
Old 07-07-2012, 09:06 PM   #4
There has not been any play or movement in the roof since the storm. The seams all appear to be intact, there was no leakage from the heavy rains that have followed since the wind. The biggest gap from the cross-boards to the tin in the attic is about an inch. I'm figuring I can use a wood block and hammer to tap the nails back into place from the outside, then use the screws to re-secure the roof.
Old 07-07-2012, 09:10 PM   #5
Pro Slate Roofer
tinner666's Avatar
Leave it alone. You may never have a leak as it is. It will leak if you put screws in it. You will create a tear or two by beating on it and cause a leak.
The Following User Says Thank You to tinner666 For This Useful Post:
Windows on Wash (07-08-2012)
Old 07-07-2012, 09:13 PM   #6
Pro Slate Roofer
tinner666's Avatar
If it was serious, the proper repair would be to unseam the nearest 'good' panel and reinstall as necessary.
And BTW, lots of so called roofers put the panels on close together and they lift as they oilcan when the temp rises.
http://www.albertsroofing.com/Tin%20...to_gallery.htm
Old 07-07-2012, 09:14 PM   #7
It's pretty much the entire lengths of the 2nd, 3rd, & 4th panels from the right side of the roof.
Old 07-07-2012, 09:17 PM   #8
Pro Slate Roofer
tinner666's Avatar
Wasn't too professionally installed then. They should have withstood an F2 tornado. Or higher. Those need to be removed and replaced.
Old 07-07-2012, 09:17 PM   #9
Tinner - Thanks for your help. I'll leave it alone.
Old 07-07-2012, 09:18 PM   #10
I'll call someone on Monday. I'm in the Buena Vista area. Any recommendations?
Old 07-07-2012, 09:19 PM   #11
Pro Slate Roofer
tinner666's Avatar
I'll get back tomorrow. Gotta situation here at home tonight! lol
Old 07-07-2012, 09:19 PM   #12
Pro Slate Roofer
tinner666's Avatar
Not for that area. I'm 80 miles out myself.
Old 07-07-2012, 09:22 PM   #13
Again, Thanks. And good luck with the crisis!
Old 07-08-2012, 02:45 PM   #14
old timer
If you could see the nails from the underside of the roof (in the attic) you might be able to grip them with vise-grips or similar, pull them down and then bend them over. If they are not all the way out of the wood. Just a thought.
dmc@RCR is offline   Reply With Quote
The Following 2 Users Say Thank You to dmc@RCR For This Useful Post:
Tom Struble (07-08-2012), Windows on Wash (07-08-2012)
Old 07-08-2012, 08:15 PM   #15
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,622
+1
Don't put a screw in it.
+1
See if you can pull it back in and throw a dab of construction adhesive on the nail shank to keep it from coming back through.
rubber roof over tar & thoughts on quote wfmrules3 Roofing/Siding 13 10-16-2011 09:00 PM
EPDM - flat roof to sloped roof transition emtaboy Roofing/Siding 12 07-14-2010 12:12 AM
Roof leaks, seems at seam of two rooflines mmeiners Roofing/Siding 4 12-31-2009 12:04 PM
Laying new roof after removal of old roof rupal Roofing/Siding 9 11-30-2009 04:00 PM
standing seam over purlins hawaiidiy Roofing/Siding 5 11-21-2009 07:00 PM
