Standing Seam Roof - Trim Question - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 09-10-2006, 03:32 PM   #1
We will be installing a new standing Seam roof, a newbie at this.
Can someone explain where Rake trim goes, as opposed to Eave trim.
what are the differences between these two items.
jpleasants2 is offline   Reply With Quote
Old 09-10-2006, 04:31 PM   #2
General Contractor
joasis's Avatar
Rake trim is on the gable ends, and makes the transition from roof panels to the vertical trim. Eave trim is on the eaves of the roof, at the ends of the panels, and protects the fascia or "trims" the facia. Are you really prepared for this task? SSR installs are not typically a DIY project and I would strongly suggest you seek some expert advice in your area, or mke sure you understand the installation process...the company that sold you the material should be able to advise you. Good luck.
joasis is offline   Reply With Quote
Old 09-11-2006, 04:15 PM   #3
Rewards Points: 150
It goes on the Rake.
RooferJim
now seriously folks the rake edge is the gable.
RooferJim is offline   Reply With Quote
Old 02-23-2009, 11:25 AM   #4
woodboy's Avatar
Drip Edge cover both parts of roof
I had drip edge cut so that it can overlap both the eaves and gables. I can also lock the standing tin down on the the eaves and also on the gable ends as well.
woodboy is offline   Reply With Quote
Old 02-23-2009, 11:43 AM   #5
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
The panels get locked on rakes and eaves the same. Check out this other thread. overlapping standing seam tin
tinner666 is offline   Reply With Quote
First course and trim question Crackers Roofing/Siding 1 08-16-2007 10:21 PM
Standing seam metal or membrane for 1.4/12 pitch shed roof? regulajo Roofing/Siding 21 06-18-2007 08:58 AM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 06:17 AM
roof louver question vinman Roofing/Siding 3 08-18-2006 08:53 PM
Torch Roof Replacement Question Chad262 Roofing/Siding 6 09-21-2005 07:29 AM
