Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 11-20-2009, 01:17 AM   #1
standing seam over purlins
I live in Hawaii and want to re-roof. I currently have cedar shakes over 1x4 purlins spaced every 12". I want to install a standing seam metal roof. I plan on removing all of the old cedar shakes and felt. my question is, should I put solid decking on top of the purlins and then an underlayment (sharkskin), or can I just put the sharkskin on top of the purlins and then the standing seam and save the cost of the decking (OSB)?
hawaiidiy is offline   Reply With Quote
Old 11-20-2009, 06:14 AM   #2
Pro Slate Roofer
tinner666's Avatar
Just install the roof over the purlins. Underlay shouldn't be necessary if done correctly, and the ceiling/attic area is sealed from indoor condensation.
http://www.albertsroofing.com/Tin%20...to_gallery.htm
Frank
tinner666 is offline   Reply With Quote
Old 11-20-2009, 06:30 AM   #3
Morning Tinner, why is an underlayment not neccesary if vapor barrier is done correctly inside?
bronco2 is offline   Reply With Quote
Old 11-20-2009, 06:41 AM   #4
Pro Slate Roofer
tinner666's Avatar
If moisture hits the underside of the metal, and the temp difference is a certain ratio, it will rain inside the home on a clear day.
Frank
Old 11-20-2009, 09:21 PM   #5
Cause he said so!!!LOL.Tinner don't need no stinkin' underlayment!!
johnk is offline   Reply With Quote
Old 11-21-2009, 08:00 PM   #6
Thanks for the reply. I think I will install decking first and then underlayment. More labor and more material cost, but a much better roof, don't you think?
Standing Seam Ridge Vent A.Pierce Roofing 8 08-04-2010 04:29 PM
DIY Standing Seam Roof stubits Roofing 5 05-14-2009 11:58 AM
Standing seam metal in NJ pcampbell Roofing 1 05-12-2009 08:10 PM
Standing Seam Roof - Trim Question jpleasants2 Roofing 4 02-23-2009 12:43 PM
Standing seam metal or membrane for 1.4/12 pitch shed roof? regulajo Roofing 21 06-18-2007 09:58 AM
