Standard Thickness Of Roof Sheathing In Phoenix - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 02-07-2011, 11:07 AM   #1
Standard thickness of roof sheathing in Phoenix
What is the standard thickness of roof sheathing used in Phoenix? My problem is that I have nails protuding through the soffit of my home after getting my roof replaced. The roofer wants to grind the nails but I'm afraid the shingle warranty will be void if that happens. How do I find out the thickness of the sheathing?
bethmac1221 is offline   Reply With Quote
Old 02-07-2011, 01:20 PM   #2
Rewards Points: 85
If you have access, try to put a thin ruler between 2 pieces of sheathing from inside the attic to measure the thickness. There should be a small gap to do so.
What kind of soffit do you have? Any pics? If it is an open soffit with nails coming through the finished wood then they probably used nails that are too long. As far as grinding down nails, I believe as long the wood there is 3/4 inch thick there should not be a problem with warranty. Most recommend that they go through the sheathing or if it's thick than at least 3/4 inch depth.
housegsx is offline   Reply With Quote
Old 02-07-2011, 03:43 PM   #3
I included a couple of photos that show the nails. From my view, it appears that the nails definitely protrude much further than 1/8".
I've had many issues with the contractor, including the overall messy workmanship. Found over 200 nails around property and still finding more today.
I don't trust what they are telling me so any suggestions are welcomed.
Standard thickness of roof sheathing in Phoenix-back.jpg   Standard thickness of roof sheathing in Phoenix-side.jpg
Old 02-07-2011, 04:37 PM   #4
Registered User
Rewards Points: 5,216
The sheathing thickness should meet Code for your area. If they only installed shingles, and not sheathing (as per contract), you have have specified shorter nails at the soffits and gable overhangs so not to be exposed. Minimum Building Code requires through the shingle plus 3/4", as said. http://publicecodes.citation.com/ico...005_par007.htm
If the sheathing is thinner, which it appears, the nail will penetrate through. But; the soffit and overhangs are not a structural part of the roof, ending at the wall and the bird-blocking. So they could have used shorter nails there, per Code--- but probably not meet the shingle manufacturers directions for the warranty. Read the wrapper for the shingle or contact the manufacturers website for confirmation.
The shingle soffit drip edge is very short and lacking drip-edge metal.....
Gary
Old 02-07-2011, 05:05 PM   #5
RFN-4A-LVN
Roofmaster417's Avatar
A responsible contractor would have known the results of installation of any roof system over any overhang using that length of fastener.The contractor should have known installation requirements and or allowances by the manufacture.It is the installers responsibility to know this.
When installing Certainteed shingles on a roof deck that spans an open overhanging area and the fasteners would be protruding through the underside of the deck would be aestheticaly objectionable.
Certainteed allows the use of shorter fasteners that do not penetrate through the roof deck.
This exception to the Certainteed fastener requirement applies ONLY in the Certainteed northwest and southwest.
ID,OR,WA,NM,WY,CA,AK,HI,UT,AZ,NV and CO.
The certainteed limited warranty covering its shingles will remain in force IF the shingles have been installed over a suitable roof deck with appropriate fasteners EVEN if they do not penetrate to the FULL depth specified in the shingle application instructions,IF the following conditions are met.
*IMPORTANT* 2 extra fasteners per shingle are required and the fastener has to penetrate the decking by at least 3/8" and seat firmly against the shingle surface.
This exception ONLY applies to the areas of the roof deck that spans the overhanging area.
Conduct a "field test" to insure that the minimal penetration has been met or exceeded.
The best fastening results when the fastener points just barely splinter the underside of the deck.
**Check your local building code for applicable fastener requirements.**
ALL other areas of the roof deck MUST contain the proper number and length of fasteners.
Most manufactures follow these same requirements/allowances.I woud snip the heads off then repaint,rather than disrupting the shingles.
Roofmaster417 is offline   Reply With Quote
Old 02-07-2011, 05:37 PM   #6
Registered User
Thanks for that! Just remember to prime the steel nails after you cut the galvanizing off......
Gary
Old 02-07-2011, 07:57 PM   #7
Considering that I contacted Certainteed to ask about the warranty and the response I received was -
Here are the instructions from our installation manual regarding nailing requirements. Grinding the nail down is not acceptable and could void the warranty.
FASTENING
t
Figure 12-2: Proper and improper nailing.
IMPORTANT: For decks 34" (19 mm) thick or thicker, nails must go
at least 34" (19 mm) into the deck. On thinner decks, nails must go
at least 18" (3.2 mm) through the deck.
Nails must be 11- or 12-gauge roofing nails, corrosion-resistant,
with at least 38" (9.5 mm) heads, and at least 1" (25 mm) long.
...and, it appears that I have a deck thinner than 3/4", it sounds like I should not grind or snip off the heads but leave as is and just paint over the nails. Is that right? I hate to jeopardize the warranty and really don't trust the workmanship of this contractor.
I appreciate the response that "a responsible contractor would have known the results of installation of any roof system", especially since the people I am dealing with make it seem like the only way to properly install a roof is to have nails showing. Approximately 30% of the homes in my neighborhood have had roofs replaced within the past 4 months and I haven't seen any with protruding nails like mine. So much for doing my due diligence and making sure the contractor was licensed, bonded/insured and in good standing with the BBB.
At least I was able to get factual results from you, and for that...thanks!
Old 02-07-2011, 08:08 PM   #8
RFN-4A-LVN
FASTENING
t
Bethmac, my reply was directly out of the Certainteed application manual.I also know this and practice the techniques all the time.I would not try to overthink the situation.Snip the heads and repaint.Or have them remove the shingles and use a shorter fastener.
Old 02-07-2011, 08:12 PM   #9
RFN-4A-LVN
bethmac,even though the points are snipped off the nail is still doing its job.Those gun coil nails have metal barrs on the sides.Those assist on the fastening.
Old 02-07-2011, 08:21 PM   #10
Got it...thanks, Roofmaster. You're right, I was overthinking the whole thing. Thanks
Old 02-07-2011, 08:24 PM   #11
RFN-4A-LVN
Hey its o,k Your worried about your home.You feel snookered and its completly understandable.I would hope that your not going too repaint yourself? I might catch flak from other users on this site but I feel that the contractor is completely responsible.Good luck.
Mold on roof sheathing!!! DIYMILF Roofing/Siding 10 08-14-2011 10:11 PM
Need opinion on this roof profenx Roofing/Siding 14 10-12-2010 01:56 AM
Strange Winter Roof Leak Dragon Roofing/Siding 16 10-09-2009 07:06 PM
Roof sheathing overhang on fascia Clutchcargo Roofing/Siding 7 08-23-2007 02:02 AM
warped roof sheathing arizonahiker Roofing/Siding 13 11-17-2005 01:53 AM
