Are Stainless Steel Screws Necessary For Installing Aluminum Soffits? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 06-29-2013, 11:14 PM   #1
Are stainless steel screws necessary for installing aluminum soffits?
Hi, new member though I have been reading posts for a long time. Anyways, I am installing soffit and fascia on a house I am building, wondering if regular steel screws will be ok of if stainless are needed. They will be covered by the lip of the fascia, I don't really care if they change color. What say the experts? Thanks a bunch.
Tim
Timmy8 is offline   Reply With Quote
Old 06-30-2013, 12:38 AM   #2
roofingquotes's Avatar
This is a good article i found in handyman about installing aluminum soffits. Thought this might help you. Check it here: http://www.familyhandyman.com/roof/h...-free/view-all
roofingquotes is offline   Reply With Quote
Old 06-30-2013, 06:55 AM   #3
Rewards Points: 14,306
Use aluminum roofing nails.
Screws should not be used.
Old 06-30-2013, 08:21 AM   #4
Rewards Points: 528
Tim
OK, here is the deal. Screws are not needed for soffits.
A little clew, I have stapled soffits for years and have never had a problem
Stop watching Holmes who seems to be paid by screw manufacturers to pr mote screw usage. Screws have there place, soffit is not one of them.
framer52 is offline   Reply With Quote
The Following User Says Thank You to framer52 For This Useful Post:
kwikfishron (06-30-2013)
Old 06-30-2013, 04:58 PM   #5
Lord of Slums
Rewards Points: 1,974
Very good article. I always make sure too nail the j channel at the very end and beginning of every piece. I have seen where the j channel is nailed maybe 8 inches from the edge and a strong wind will collapse it.
mj12 is offline   Reply With Quote
Old 06-30-2013, 05:13 PM   #6
No way would I use staples.
I'm the guy that has to go in after some things failed and fix it.
Every time the staples have rusted off long ago. Even if they use monel, they have pulled out.
Using staples would be a slam bam thank you and move on to the next job way of doing it.
Old 06-30-2013, 06:31 PM   #7
Rewards Points: 528
Joe, I am the one responsible for what I do.
In installing in excess of 10,000 square of siding and soffits I have never had a call back over a stapled soffit. Funny part is, I have yet to find any that have rusted.
now where you live they might, i don't know.
by the way, I have changed soffits for customers I did 30 years ago, have you?
Old 07-01-2013, 10:37 AM   #8
I don't have a staple gun for soffit and I want to use screws. Just wondering if stainless are needed...
Old 07-02-2013, 09:04 PM   #9
Lord of Slums
I want no part of ss screws, they will not stay on the drill tip
Old 07-03-2013, 03:26 PM   #10
Roofmaster
Rewards Points: 2,210
If you are installing a lot of soffit it is worth it for you to pick up a pneumatic staple gun. I have a Hitachi that I used to install my soffit with 1.25 x 1/4 inch plated staples. The nose gets up in the ribs and installation really goes fast. Joe is probably right about removal, but I do not intend on removing my fully vented soffit any time soon.
Stainless steel cleaner dinosaur1 Appliances 10 12-19-2011 11:28 PM
Stainless Steel Sink is rusting after only 2 months acerunner General DIY Discussions 14 09-27-2011 06:57 PM
How to clean stainless steel grill?? JohnnyD44 Appliances 2 07-21-2011 08:32 AM
Aluminum flashing with galvanized roofing and screws duffy mohawk Roofing/Siding 7 06-03-2011 09:02 AM
Stainless steel deck screws and hardibacker johnknez Building & Construction 1 10-09-2009 08:56 AM
