Staggering Seams On Vinyl Siding? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 09-04-2013, 03:46 PM   #1
Staggering seams on vinyl siding?
How do you guys like to stagger your seams on vinyl siding? I have seen houses that they stair step the seams, almost like you do to get your stagger on shingles, I have seen where you use the piece that you end up cutting off the last piece as your starter for the next course but then the seam lines up vertically every other course. Or I've seen a random pattern which to me makes the seams less noticeable. What do you guys prefer, do you have a method for figuring out your stagger keeping efficiency and waste in mind?
Yeti is offline   Reply With Quote
Old 09-04-2013, 04:31 PM   #2
Rewards Points: 2,238
If you "stair-step" the seams like they used to do with aluminum -
It "sticks" out.
You can see a pattern.
Also, there are other considerations.
We usually try to make them random - 3ft. (+-) apart.
"RF"
rossfingal is offline   Reply With Quote
The Following 2 Users Say Thank You to rossfingal For This Useful Post:
HomeSealed (09-06-2013), joecaption (09-04-2013)
Old 09-04-2013, 04:36 PM   #3
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,058
i do the same thing as ross, typically whatever is left from a piece that finishes a run ill use the offcut to start the next course.. however if a pattern starts to form ill break it up by cutting some off the starter piece
woodworkbykirk is offline   Reply With Quote
The Following 2 Users Say Thank You to woodworkbykirk For This Useful Post:
joecaption (09-04-2013), rossfingal (09-04-2013)
Old 09-04-2013, 11:00 PM   #4
Rewards Points: 940
I lay out the wall considering the length of the material. I seem to have a lot of 24' walls on 24x24 garages, so I'll go 2x12, then 3x8. I can use the 4 footers on the front beside the overhead door opening. No sense going with 4x6 because then you are just cutting up material.
cleveman is offline   Reply With Quote
Old 09-05-2013, 07:48 AM   #5
Davejss's Avatar
Rewards Points: 740
I try to find a balance between appearance and economy. I go as random as possible without being wasteful.
I don't use pieces shorter than 2 feet or so in a run and I try to avoid the stair step pattern.
Davejss is offline   Reply With Quote
Old 09-06-2013, 02:17 PM   #6
Home Performance
HomeSealed's Avatar
Rewards Points: 712
I'm with the other guys, go random without wasting. Stair step looks terrible.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Vinyl Siding Help Needed swiederin Building & Construction 4 10-24-2011 10:02 PM
Vinyl siding over wood travem Remodeling 6 02-06-2011 11:32 PM
Vinyl siding over cedar siding dbldee20 Remodeling 8 02-21-2009 08:06 AM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
