Stagger On Timberline Architectural - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 06-06-2012, 12:05 AM   #1
slk
stagger on timberline architectural
gaf timberline hd says to use this stagger on a shingle with a 39 3/8 width:
row 1 - full
row 2 - remove 6"
row 3 - remove 11"
row 4 - remove 17"
row 5 - repeat pattern starting with full.
Why don't they recommend the staircase stagger going a few more rows (row 5 remove 23", row 6 remove 29"..)?
It just seems more efficient, of course wtf do I really know about roofing...
Thoughts?
slk is offline   Reply With Quote
Old 06-06-2012, 05:20 AM   #2
Rewards Points: 14,026
The directions are right on the bag of shingles.
As long as the butts are at least offset 6" and do not line up with the one directly above it, it will look and work fine.
Old 06-06-2012, 08:21 AM   #3
slk
My shingles don't have instructions on them so i got this off the web.
http://eliteroofingofnashvilledisast...structions.jpg
Unless someone convinces me otherwise I'll probably keep staggering in pattern for another couple rows. Thanks.
Old 06-06-2012, 09:11 AM   #4
Rewards Points: 1,300
It is possible they do not want shingles shorter than that as end of row shingles.
danpik is offline   Reply With Quote
Old 06-06-2012, 11:37 AM   #5
ah, makes sense.
i guess it's what i feel comfortable with. 11" seems good to me to start a row with so I'll probably do this...
row 1 - full
row 2 - remove 6"
row 3 - remove 11"
row 4 - remove 17"
row 5 - use 17" cutoff from row 4.
row 6 - use 11" cutoff from row 3.
row 7 - full and repeat...
giving me lengths of the following for starters
1- 39"
2- 33"
3- 28"
4- 22"
5- 17"
6- 11"
7- 39"
Thanks fellas, and anyone else let me know if you're concerned with this pattern...
Geeze is offline   Reply With Quote
Old 06-06-2012, 02:28 PM   #6
MJW
Yep
Since they lowered the weight and made them even thinner than they were before, they need more of the shingle on the roof. It will lead to more waste too. Win win for GAF.
MJW is offline   Reply With Quote
Old 06-08-2012, 01:30 AM   #7
Rewards Points: 324
Originally Posted by MJW View Post
Yep
Thats why I use Certainteed. Best quality shingle available here.
mgp roofing is offline   Reply With Quote
The Following User Says Thank You to mgp roofing For This Useful Post:
bcdemon (06-08-2012)
Architectural shingles to buy vs. regular vkerns Roofing/Siding 24 08-04-2016 04:31 PM
Re-roofing Architectural Shingles over Architectural Shingles NoDIY4Me Roofing/Siding 11 04-08-2014 07:50 PM
Weight vs. durability of architectural shingles JoeT Roofing/Siding 10 06-29-2009 06:50 AM
reg. or Architectural shingles? fricandfrac Building & Construction 6 04-02-2009 04:47 PM
Do architectural shingles really work with step flashing? Malcolm Roofing/Siding 7 05-02-2008 10:31 PM
