Stack Flashing - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-22-2008, 06:47 PM   #1
Rewards Points: 150
stack flashing
the rubber/flashing boot that goes around the stack has ripped today when i was pushing the new pvc stack through. how do i go about replacing that thing?
drewhart is offline   Reply With Quote
Old 07-22-2008, 09:02 PM   #2
the roofing god's Avatar
Send a message via MSN to the roofing god
remove the nails at the perimeter of the flashing,and from upper 2-3 shingles using a "flat" bar,install a caulk bead 1" in from the perimeter of the new flashiong(on the bottom of it-karnak ultra)install a new ventpipe flashing and reinstall the same shingles,install spots of caulk where the tar lines were disturbed
"If it`s worth doing,It`s worth doing right!!"
www.ADVANCEDROOFINGNEWYORK.com
the roofing god is offline   Reply With Quote
Old 07-23-2008, 07:58 PM   #3
Grumpy's Avatar
Rewards Points: 540
Send a message via AIM to Grumpy Send a message via MSN to Grumpy Send a message via Yahoo to Grumpy
Go to a roofing suppky shop and buy a proper lead stack flashing. Then do as TRG described above. Assuming this is a plumbing pipe that the lead can be folded into. If not make sure when youg et the new rubber gasket it has a metal base. They are much more stable than the all rubber boots which usually don't last more than a year or three.
We replace ALOT on the tract homes built by the production builders. Quantity over quality? Bad idea. That's why we use the lead when ever possible.
-Grumpy http://www.illinoisroofinspections.com
The information found in this post is not to be considered legal advice. The author of this post takes no responsibility for any losses that occur. Use at your own risk.
Grumpy is offline   Reply With Quote
Old 07-24-2008, 06:45 PM   #4
If you do install the Lead Plumbing boot, make sure that you only trim off the excess lead to a point that goes at least 1" to 1 1/2" above the top of the actual pipe.
Then either use the handle of your roofing hatchet or hammer or a rubber mallet and Gently tap the Lead into the inner circumferance of the pipe, until it folds neatly, without any tears, into the pipe.
Ed
Ed the Roofer is offline   Reply With Quote
Corrosion problem in vent stack. sgbotsford HVAC 2 12-01-2007 02:47 PM
Cast Iron Vent Stack Flashing mhrichman Roofing/Siding 9 10-04-2007 09:12 PM
Plumbing vent flashing FatAugie Roofing/Siding 7 08-24-2007 08:30 PM
DWV Stack Question dcgray2 Plumbing 9 07-14-2006 12:56 PM
Flashing problems Slave Building & Construction 3 11-16-2005 03:56 PM
