Is This Stabilizer Worth The Truck Space - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 05-10-2013, 11:58 AM   #1
Lord of Slums
Rewards Points: 1,974
Is this stabilizer worth the truck space
http://www.bigrocksupply.com/store/p...tabilizer.html I know I would use this stabilizer, but number one, does it look safe. Does Werner make something like this? My space is limited, I can not carry stuff around I will not use. Any comments, thanks
mj12 is offline   Reply With Quote
Old 05-10-2013, 12:06 PM   #2
Doing This Way Too Long
Rewards Points: 532
Well, how often do you have the need to put a ladder up on the corner of the bldg? Simple as that.
OldNBroken is offline   Reply With Quote
The Following User Says Thank You to OldNBroken For This Useful Post:
jagans (05-10-2013)
Old 05-10-2013, 02:04 PM   #3
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
I have one and to me, they are unstable if you reach out to either side. You're farther out, and the footprint on the building is probably less that a foot wider.
They're usable, but use caution.
tinner666 is offline   Reply With Quote
Old 05-10-2013, 02:46 PM   #4
Lord of Slums
well unstable to me means I do not want it. I spend a good deal of my day on ladders and I am all ears when someone says to be careful. I actually had one of these before but never used it. Gave it too a friend that said he liked it when he had to fix a seam on a gutter corner miter.
Converting Vented Crawl Space to Unvented/Conditioned Achille76 Building & Construction 4 02-19-2013 09:10 PM
30" freestanding range in 36" end space jeffzap General DIY Discussions 3 12-28-2012 08:18 AM
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
Crawl Space Advice mjarema414 Building & Construction 0 02-04-2011 08:09 AM
How to finish closet ceiling in garage space bob22 Building & Construction 2 12-18-2010 02:10 AM
