Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 04-12-2009, 02:23 PM   #1
Mechanical Engineer
Default Squirrels chewing the gutter guards...
I've got some vinyl gutter guards on the front and back of my house, and they've worked really well. The only issue I've had is having these damn squirrels chewing the plastic and nesting inside the gutter. The gutter has a criss-cross pattern opening, covered by a thin plastic screen. The squirrels get into the gutter from the side and then chew the vinyl, and push up through the screen from underneath. We are within city limits, so shooting them is out of the question.
Of course, that's the option I like best. 'Squirrel' is just another name for rodent.
Anyway, if you've had similar problems, what methods have worked? Are there metal gutter guards available? I know they are more expensive, but at the rate that I'm replacing these, it would be worth the cost.
Thanks.
gshock is offline   Reply With Quote
Old 04-12-2009, 02:47 PM   #2
Roofing Contractor
Leftyho's Avatar
Hi,
Leafproof will work for you.
Leftyho is offline   Reply With Quote
More On This Topic
Hi this is Jon on behalf of Expert Village in this video clip I will show you how to remove your side trim boards. On this side we need to remove our gutter first before we can have access to our trim board. You need to unscrew where you gutter... Read More »
How to Clean a Roof Gutter
How to Clean a Roof Gutter by Expert Village
Hi, this is Jon on behalf of Expert Village in this video clip we'll be cleaning and inspecting the gutters and down spouts. Now the gutters are another area that require a little extra attention. If your gutters are clogged and during the winter we get... Read More »
During the winter months heavy snowfall can cause a buildup of snow on your roof. The weight of the snow can cause damage to your roof, or even cause it to collapse. Follow these guidelines to learn how to keep snow off your roof for wintertime... Read More »
Rain gutters are one of your home's defenses against structural damage both to the facade, as well as to the foundation. If your rain gutters begin to fail then the integrity of your home's structure can become compromised. It is possible to repair your... Read More »
Gutters drain rain water away from your home and its foundation. Repair broken gutters as soon as possible to prevent major damage to your home. Aluminum, vinyl, copper and galvanized steel are the most commonly used materials for gutters. Evaluate each... Read More »
"Frozen" Gutter Leak cougar01 Roofing 19 02-10-2009 08:07 AM
Gutter Heaters kennykenny Roofing 12 10-25-2008 10:07 PM
Waterfall gutter guards needhamhome Roofing 0 10-03-2008 12:51 AM
How can I remove my gutter / apron with out pulling the first row of shingels wamyers92 Roofing 3 07-02-2008 04:10 AM
Proper way to install gutter flashing? Kasfidan Roofing 3 03-17-2008 02:57 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
