Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 11-13-2007, 02:28 PM   #1
Squeaky Turbine Vent
The turbine vent on my roof is constantly squeaking. What is the best way to fix this? Do I replace the cap? If so how is this done?
The vent is barely 3 years old.
ksettle is offline   Reply With Quote
Old 11-21-2007, 01:50 AM   #2
the roofing god's Avatar
Send a message via MSN to the roofing god
use grease where it turns,don`t use wd-40 as it`s only a temporary solution
"If it`s worth doing,It`s worth doing right!!"
the roofing god is offline   Reply With Quote
Old 11-21-2007, 08:19 AM   #3
I guees I need to remove the turbine to do that. There a a few screws on the outside I need to loosen?
AIR VENT SHINGLE VENT ll Docfletcher Roofing 8 06-04-2011 10:05 AM
can I 'patch in' a bathroom vent into my kitchen's stove hood vent? joeyboy HVAC 2 09-10-2007 01:36 PM
Yoke vent for water closet kenlog Plumbing 4 07-13-2007 07:34 PM
Bathroom Vent Not Vented to Outside / Would need to vent through flat roof House_Amuck HVAC 5 03-30-2007 10:57 AM
Ridge Vent - Low-pitched roof? brianp Roofing 2 05-08-2006 09:32 PM
