Is Spray Foam Insulations Guaranteed? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 04-02-2009, 12:01 AM   #1
Is Spray Foam insulations guaranteed?
Hello, I am Shane. I would like to know about spray foam insulation. What is the typical cost and is it guaranteed?
shanemcguire1 is offline   Reply With Quote
Old 04-02-2009, 05:22 AM   #2
Remodeling Contractor
Typical costs is twice other insulation applications. Much better job and about a 5 year payback. But a guarantee for what?
Old 04-03-2009, 12:22 AM   #3
Guarantee means, does it effective for preventing moisture, fire etc.?
Old 04-03-2009, 03:53 AM   #4
747
registered
747's Avatar
Rewards Points: 534
It doesn't require a vapor barrier. Its definately the best insulation out if you can afford it. Fire prevention. You just touch it with a torch and look out. This is why you don't ever want to spray under floors where there is copper piping. If A plumber pulls out a torch to sweat a pipe connection and just touches the insulation. Its all over with. You wouldn't believe how quick that stuff will go. The hole thing will be on fire and he won't be able to contain it.
747 is offline   Reply With Quote
Tags
spray on foam insulation
Spray foam insulation troyce1 Insulation 12 12-14-2014 06:30 AM
spray foam insulation mikeybobo Building & Construction 11 06-19-2010 04:04 PM
spray foam insulation MikeyP Building & Construction 3 01-25-2009 02:48 PM
Spray Foam/ Foam Board Hybrid? entropyracer Roofing/Siding 2 09-19-2008 07:12 PM
Spray foam simonb Building & Construction 6 11-30-2007 07:11 AM
