Spray Foam Between Rafters..closed Ventelated Attic - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 08-08-2014, 06:01 AM   #1
Spray Foam between rafters..closed ventelated attic
My Owens Courning Pro 30 shingles are looking pretty rough after only 11 years. Lost a lot of granules and a very few corners are curling. Can't help but wonder if the 5" open cell spray foam (applied 2009) on the underside of the roof decking has anything to do with the granule loss...
Anyway, trying to find a shingle manufacturer that warranties shingles that are installed in closed ventilated attics. OC does not...what is the best shingle manufacturer to use?? I would like to get more years out of them next time.
alan1300 is offline   Reply With Quote
Old 08-08-2014, 10:31 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,564
In New Orleans, it is super hot and depending on where that roof is facing and color, that shingle temp will be super hot.
The Following User Says Thank You to Windows on Wash For This Useful Post:
roofermann (08-08-2014)
Old 08-08-2014, 10:51 AM   #3
HDS
Rewards Points: 204
How about a metal shingle/roof instead? Another option would be creating a ventilation layer above the roof deck when you replace the roof. Something along the lines of the left hand side of the pic below.
HDS is offline   Reply With Quote
The Following User Says Thank You to HDS For This Useful Post:
iLikeDirt (08-08-2014)
Old 08-08-2014, 11:11 AM   #4
If it can be done, I always prefer a vented option.
PatChap (08-08-2014)
Insulating unvented attic w/ 2x4 rafters? rion.martin Insulation 6 04-27-2014 06:43 AM
highest R-value spray foam MLMIB Insulation 12 02-16-2012 02:33 PM
closed cell vs open cell foam insulation amonalisa Building & Construction 1 11-06-2008 09:39 PM
closed cell insulation in attic Dennis Doucette Building & Construction 7 03-16-2007 09:08 PM
