Special Spray For Roof Exhaust Vent's? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 12-23-2008, 12:30 PM   #1
Special Spray for Roof Exhaust Vent's?
Is there a special spray for the roof exhaust and vents? Will any exterior metal spray work? Should I clean up the vents a little or just cover around it and spray?
amdspitfire is offline   Reply With Quote
Old 12-24-2008, 07:23 AM   #2
Prep as you would any metal surface. Scrape off loose rust with a steel brush, clean of oil, tree sap, etc., with paint thinner then alcohol. Prime with a metal primer and spray, several coats. I like Krylon, it drys fast, rustoleum is probably better for rusty surfaces, but slow drying.
Old 12-25-2008, 01:37 PM   #3
Thought these roofers had something special, guess not. Will take care of it once the rain stops. Thanks.
Old 12-26-2008, 11:46 AM   #4
We do have something special.It's called remove and replace.
johnk is offline   Reply With Quote
Bathroom exhaust... the ongoing saga... landev HVAC 9 01-05-2009 08:49 PM
Removing some vents rdmccaw HVAC 4 10-22-2008 02:00 PM
ridge/soffit vents not enough?? cbice74 Roofing/Siding 1 06-16-2008 06:02 PM
sofit vents + gable end vents no ridge vent mattg1970 Roofing/Siding 5 10-18-2007 10:47 AM
