Spanish Tile Roofing - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 12-11-2013, 08:46 PM   #1
Rewards Points: 99
Spanish tile roofing
Need to remove some Spanish tiles from a roof so I can install new flashing for a furnace flue pipe. Any advice on doing that? I won't be reinstalling the tiles so no worries there.
Thanks!
kirwinjd is offline   Reply With Quote
Old 12-11-2013, 09:03 PM   #2
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
"I won't be reinstalling the tiles so no worries there."
Why? You need to elaborate on that. Flashing alone won't cover the issue.
The tiles should just lift off with only a copper nail at the tops. You'll need 4# sheet lead to flash in the collar.
tinner666 is offline   Reply With Quote
Old 12-12-2013, 08:11 AM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 826
Pictures and more detailed explanation on the lack of tile put back.
Old 12-12-2013, 11:00 AM   #4
Rewards Points: 99
Originally Posted by Windows on Wash
+1 Pictures and more detailed explanation on the lack of tile put back.
Thanks for the response. Sorry I didn't explain why I'm not putting the tiles back on.
My new furnace installation is due for inspection tomorrow and the homeowner can't reach the roofing contractor. To be ready for the inspection, I need to install my flue vent and roof jack. As long as I can get that done, the owner can have a qualified roofer properly reinstall the roof tile later.
Old 12-12-2013, 03:56 PM   #5
Rewards Points: 826
Sounds good.
Good luck with the project.
Old 12-12-2013, 05:02 PM   #6
Pro Slate Roofer
tinner666's Avatar
Well, DO NOT nail anything to the roof deck then. The flashing has to be weaved into the tile and it will be suspended from the deck.
Spanish tile roof kirwinjd Roofing/Siding 0 11-22-2013 11:07 PM
Tile Repair - Filling Void, Reusing Tile Jdubya57 Building & Construction 0 07-09-2012 12:21 PM
Tile over Tile ?? Piney Flooring 17 02-06-2012 10:59 PM
Roofing Material History Roofmaster417 Roofing/Siding 4 09-08-2011 05:49 PM
tile man used mastic glue on entrance to shower keyesww Tiling, ceramics, marble 13 06-08-2010 05:39 PM
