Soythane Sprayfoam Kits - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 01-09-2008, 10:38 AM   #1
soythane sprayfoam kits
Any opinions about soythane sprayfoam kits?
Saw it on ebay:
http://cgi.ebay.com/Spray-Foam-Insul...QQcmdZViewItem
Although it isnt cheaper per sq ft than the other DIY kits out there, it appears to have a better gun/delivery system than the typical pressurized tank "handifoam" or "tigerfoam" kits out there. Then again, looks can be deceiving.
I have many small separate areas that need spraying where a kit could make sense - otherwise hiring a pro with the $25K+ spray rig would be the way to go.
rodeo is offline   Reply With Quote
Old 07-10-2008, 10:01 PM   #2
I noticed this product as well, and it appears to cost a little less than others. Did you try it out?
rmcfall is offline   Reply With Quote
Old 07-10-2008, 11:52 PM   #3
I know, or I should say, that almost all of the Roofers who post Here know the Owner/Inventor of that product and a few have stepped up their businesses with it using the SprayMax FastKick gun.
It works just as advertised and is simple to use.
The mans name is Tom and if you want, I will see if he could come over and answer your questions for you ersonally.
Ed
Ed the Roofer is offline   Reply With Quote
Old 07-10-2008, 11:54 PM   #4
I would definitely recommend these kits.The guy that invented the soythane has been in the foam industry for more than 40 yrs.You can see more info at www.Soythane.com
johnk is offline   Reply With Quote
Old 07-15-2008, 12:10 AM   #5
the roofing god's Avatar
Send a message via MSN to the roofing god
best system on the market,visit his website
"If it`s worth doing,It`s worth doing right!!"
www.ADVANCEDROOFINGNEWYORK.com
the roofing god is offline   Reply With Quote
Question about Wainscoting kits Krichton General DIY Discussions 8 12-29-2009 09:18 AM
Shed Kits Piney Building & Construction 8 04-20-2009 11:56 PM
Oak Stairways...are there kits? SeanR Carpentry 3 10-26-2007 10:23 PM
