Something Pushing Up My Shingles??? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 10-06-2010, 07:48 AM   #1
cai
Something pushing up my shingles???
Hi,
I have recently noticed that many of my shingles look as if something is pushing it up. My 2-year-old roof looks like it has humps all over the place. As if nails popped and is pushing up on the shingles. I attached a few pictures for visualization...(if needed I can upload more)
Contractor says it's probably caused by having to much glue and is not an issue. I am having a hard time getting him to repair it.
Any insight is greatly appreciated.
thanks.
Something pushing up my shingles???-roof.jpg   Something pushing up my shingles???-closeup.jpg
cai is offline   Reply With Quote
Old 10-06-2010, 09:13 AM   #2
Rewards Points: 476
not a ruffer but have laid some shingles . Look's like they were butted up to close to the next 3 tab ?? that would make them not lay down. I belive their ia a small space between the big part of the single . their is a small tab at the botton and top for spaceing ? As for to much glue Bull crap Their is a small piece of paper across the glue line. Now if this is not taken off it will not tack down. I belive ii is like the black bull for caulking, Call out the home inspecter for that county and let him look at it. They will make the installer fix or no more in this city . just my 2cents
del schisler is offline   Reply With Quote
Old 10-06-2010, 10:18 AM   #3
Rewards Points: 106
Not sure what the solution is, other than replace it, but as for the problem, I suspect that it is not nails popping, but rather the ends of the covered shingles that come across the valleys from the connecting roofs, that are curling up. Not that it makes it right, but it's probably a bit better situation than having nail heads cutting into the shingles. Anyway, I will be interested in what any experts have to say, but I am going to be venture out on a limb, and guess that because of the steepness of your roof, those covered tails are stretching or sliding downward, and bunching up. I don't work on roofs that steep, so don't know if it will go so far and stop, or what, don't know if those particular shingles are suitable for that steep of a roof, or if proper installation procedures for that application were followed, but those are some things that I would be interested in seeing some experts post on.
Old 10-06-2010, 03:58 PM   #4
MJW
How many layers on that roof? What does the deck consist of? How old is the house?
IMO, they all look very rough for being 2 years old.
MJW is offline   Reply With Quote
Old 10-06-2010, 05:47 PM   #5
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
It appears to be the valley hem, and if it's a closed valley, the bulge is more prominant.
You can see the hem on the right side of this valley.
tinner666 is offline   Reply With Quote
Old 10-07-2010, 12:52 AM   #6
Rewards Points: 956
it could also be a ventilation issue?
federer is offline   Reply With Quote
Old 10-07-2010, 05:49 AM   #7
Residential Roofer
Slyfox's Avatar
It very well could just be the lighting but I believe I'm seeing some granule displacement in some of those tabs, I would get this roof inspected, sooner than later, to make sure there's not an material failure issue.
God Family Country Work Play
Facebook <> Twitter
Slyfox Exteriors Co.
Slyfox is offline   Reply With Quote
Old 10-08-2010, 12:15 AM   #8
Rewards Points: 956
actually i see a vent up at the top so maybe not ventilation
Old 10-08-2010, 11:26 AM   #9
cai
It's a newly built house so it's 2+ years, just like the roof. And I don't know how many layers is on there. The roof is one area I'm not comfortable with and would rather not climb on.
Old 10-08-2010, 11:27 AM   #10
cai
You are correct, I do have quite a few vents not visible in these pictures...
Old 10-08-2010, 11:29 AM   #11
cai
If you are referring to the closeup picture, that would be a picture problem. My photo was quite big so I had to reduce its size to post here. In reducing the size, it introduced some granules...
Old 10-08-2010, 11:36 AM   #12
cai
On a happier not, I managed to get the contractor to come by and take a look.
I guess my next question is what should I expect/want?
From what you can see from the pictures, is it a matter of replacing the few offending shingles? Or should the whole roof be redone? Or something in between?
Basically, when the contractor comes and gives me his analysis and proposal for repair, what should I settle for?
thanks.
Old 10-08-2010, 02:59 PM   #13
Roofing Contractors
I'm planning for roofing replacement? could you recommend me the best roofing contractors in houston?
I've already found valuable info at http://www.AllTexExteriors.com
But still I need more info before finalizing my decision. Hope you can help me. Thanks in advance
Rousella Wright is offline   Reply With Quote
Replacing chimney flashing after new shingles tmiles2246 Roofing/Siding 18 04-18-2011 01:03 PM
Help! -- what is causing these shingles to fail? imaginator Roofing/Siding 1 09-18-2010 06:29 PM
Difference between "heavier" shingles, and "wind resistant" shingles Inquiring Mind Roofing/Siding 4 02-03-2010 03:21 PM
Weight vs. durability of architectural shingles JoeT Roofing/Siding 10 06-29-2009 06:50 AM
IKO Shingles - beware mtugrad1985 Roofing/Siding 7 02-10-2009 03:42 PM
