Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing/Siding
Old 01-16-2013, 05:08 PM   #1
some frost on edges of roof sheeting in Attic above garage. Also am getting frost on roofing nails.
I finished my attach garage ceiling a few years ago and insulated the ceiling also. It is a hip roof(if that matters). I heat the garage a few days a week with a protable heater. The garage door is insulated, but not the other two exterior walls. Two years ago, when it was cold outside. I noticed that the roofing nails above my garage would have frost on them. They would melt and refreeze causing littl rust spots/drops all over. I alsosaw some mold starting in attic above garage. It was then I found that there was no soffit vents around my garage area. They probably did not put them in when it was built since garage was ceiling was not finished. After noticing this, I put in 6 vents (4"x 14&quot on each of the three sides. Since it is a Hip roof, the soffit is only about 6". Last year was warm and I never saw any frost, so I thought the problem was ventilation and that I corrected it. I just had a new roof put on a few months ago and also installed a ridge vent. This year It has been colder and I noticed frost on the nails again and also some small areas of frost near edges of the roof. The home portion of my roof does not seem to have the same problem. Any ideas on what is causing this and what I should do?
Sebo20 is offline   Reply With Quote
Old 01-16-2013, 05:37 PM   #2
Got a picture?
Still not enough venting, attic area not air sealed, not enough insulation, soffit vents blocked with insulation.
Old 01-19-2013, 11:40 PM   #3
Moderator
That part of the garage is not getting any excess heat from the house, so the moisture deposited on the nails-- frosts. http://www.buildingscience.com/docum...bout-diffusion
A propane heater will deposit moisture in the air as a by-product from combustion.
Sounds like your intake vents are way undersized; 6x14 is only 25 sq.in. NFVA. What is the NFVA of the ridge vent? Bottom chart; http://www.airvent.com/homeowner/pro...it-specs.shtml
Gary
PS. Welcome to the forums!
Clothes taking longer to dry?
Old 01-20-2013, 10:36 AM   #4
Doing This Way Too Long
Am I reading you correctly? You say you installed 6 soffitt vents? I don't see any mention of ridge vents.
OldNBroken is offline   Reply With Quote
Choosing The "Right" Roofing Contractor, How To Evaluate Who Is Right! Ed the Roofer Roofing/Siding 27 04-25-2013 06:10 AM
Strange Winter Roof Leak Dragon Roofing/Siding 16 10-09-2009 07:06 PM
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 05:08 PM
New 1yr Townhome with Leaking Roof! sijunk Roofing/Siding 9 08-08-2008 04:50 PM
Help with repairing a flat rubber garage roof Toasty Roofing/Siding 2 07-01-2008 09:43 AM
