Some Basic Question About Roofing Help! - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 12-18-2005, 02:57 PM   #1
Some basic question about roofing help!
do you think it's right or wrong?
1. As a rule of thumb, 2/3 of the material must be left above the birds mouth of a rafter.
2. The ridge board should be the same width as the common rafter.
3. Shed roofs are primarily used for porches and additions to a building.
motd0iyeuem is offline   Reply With Quote
Old 12-18-2005, 03:22 PM   #2
1) OK for rule of thumb. All the stresses can be calculated. The amount of lumber left supporting an overhang after the bird mouth is cut is critical. The rafter should still be full demension at the point where the plate and the level cut start.
2) The demension of the plumb cut on the rafter at the peak is longer than the width of the rafter. Next size up as a general rule. A ridge is customary for framing site built cut roofs but is not critical from an engineering standpoint.
3)That was probably true 70 years ago. Todays designs have multiple roof planes and often include a couple of shed roofs.
That's my opinion anyway. HS.
K2eoj is offline   Reply With Quote
Old 12-18-2005, 04:48 PM   #3
Commercial Roofing
AaronB's Avatar
Originally Posted by hammerslammer
1) The rafter should still be full demension at the point where the plate and the level cut start.
What does this mean?
www.roseroofing.net/ Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Old 12-18-2005, 05:22 PM   #4
The birds mouth has a level cut and a plumb cut. Where the level cut starts, (the point furthest away from where the level cut and the plumb cut meet), the rafter should be full width and resting on the plate essentially giving the rafter full bearing and the rafter strength from wall to ridge is not affected by the birds mouth. <P>
The birds mouth does affect the overhang. If your birds mouth takes 2" out of a 2x6 then your overhang is supported by the 3-1/2" left or a 2x4. That would probably be ok on a 2' overhang but might not be enough on a 3' overhang. <P>
that's is my thinking but as always I'm open criticism.
Old 12-18-2005, 05:48 PM   #5
Commercial Roofing
AaronB's Avatar
So a 2x6 should have a full 5 5/8" resting on the plate?
Old 12-18-2005, 07:44 PM   #6
That's how I would do it. I never saw any reason to have an oversized birds mouth. They only serve to transfer all the load vertically and as a reference point. With engineering and or metal hardware birds mouths are not required at all.HS.
Old 12-19-2005, 08:15 AM   #7
Commercial Roofing
AaronB's Avatar
I never knew that, but I am not a carpenter either. Thanks for the info.
Choosing The "Right" Roofing Contractor, How To Evaluate Who Is Right! Ed the Roofer Roofing/Siding 27 04-25-2013 06:10 AM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 02:19 AM
Roofing question woodyblab Building & Construction 6 11-06-2006 09:12 PM
Rudimentary Shed Roofing Question CGofMP Roofing/Siding 11 03-31-2006 10:24 AM
very basic drywall question Knyte260 Building & Construction 3 07-18-2005 04:09 PM
