Solaris Reflective Shingles - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 08-29-2011, 02:29 AM   #1
solaris reflective shingles
What is the best type underlaylment or roofing sheathing is best prior to installing shingles and also type of fastener such as stainless or galvaninze? Also is better to install ridge vents or solar vents to cool attic and shingles above?
whitey123 is offline   Reply With Quote
Old 08-30-2011, 01:21 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,558
We prefer the synthetics (woven polypropylene) as compared to the 15/30lb felts. It is cheap insurance and we use it as a standard to avoid any blow off (ever seen stapled down felt in a thunderstorm).
Galvanized nails are fine and roof venting is best handled via continuous soffit and ridge venting and should be passive (i.e. non powered).
FYI, you are not trying to cool the attic but provide a pathway for moisture to get out. Venting has nothing to do with cooling.
Re-roofing Architectural Shingles over Architectural Shingles NoDIY4Me Roofing/Siding 11 04-08-2014 07:50 PM
Replacing chimney flashing after new shingles tmiles2246 Roofing/Siding 18 04-18-2011 01:03 PM
Help! -- what is causing these shingles to fail? imaginator Roofing/Siding 1 09-18-2010 06:29 PM
Difference between "heavier" shingles, and "wind resistant" shingles Inquiring Mind Roofing/Siding 4 02-03-2010 03:21 PM
IKO Shingles - beware mtugrad1985 Roofing/Siding 7 02-10-2009 03:42 PM
