Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing/Siding
Old 12-27-2010, 03:32 PM   #1
Soffit Vents for Wooden Soffit?
Hi,
Does anyone know of anything other than the aluminum circle vents and the square vents that lowes sells to vent wooden soffit? I have a metal roof and was told that the rips in the metal would allow ample air flow into the attic with out putting in soffit vents. I am having trouble with ice damns and now some of the perlins are getting mold on them. I suspect that I do not have ample air flow. The roof has a continuous ridge vent. I am going to try and take some pics tonight and post them tommarow. Any ideas would be greatly appreciated. Thanks for your help!
rollenrock33 is offline   Reply With Quote
Old 12-27-2010, 03:53 PM   #2
Originally Posted by rollenrock33 View Post
Hi,
You're gonna need soffit vents, If you have wooden soffits, you can use what they sell at Lowes, or you can opt to have perforated aluminum soffits installed.
The general rule of thumb is at least 1 sq ft of ventilation for every 300 sq ft of roof, equally divided between the ridge vent and the soffits. In high humidity areas, double the requirement. How long and wide is the ridge vent, and what size is your roof?
You need to make sure that the soffit vents are not obstructed by insulation so they can draw air freely.
clashley is offline   Reply With Quote
Old 12-27-2010, 07:16 PM   #3
Super Moderator
A continuous strip vent, about 2" to 3" wide, depending on the manufacturer would provide you a source of continuous Intake Ventilation, but ensure that no interior insulation would be present in the overhang to inhibit the airflow.
Ed
Stay Tuned For Our New Informative And Helpful Web Site, Coming Soon
Ed the Roofer is offline   Reply With Quote
The Following User Says Thank You to Ed the Roofer For This Useful Post:
Tom Struble (12-27-2010)
No soffit vents needed? MikeNY Roofing/Siding 4 08-24-2010 05:30 PM
Installing Soffit vents w/finished attic Nathan0115 Roofing/Siding 6 06-04-2010 10:05 PM
Soffit vents on older houses with "curved" ceilings Labman101 Roofing/Siding 2 02-07-2010 11:33 PM
No soffit or gable vents wooody Roofing/Siding 8 08-19-2009 09:06 AM
Soffit Vents Sammy Building & Construction 9 07-07-2008 07:31 PM
