Soffit Vents Tacked Not Screwed, Sagging - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-04-2012, 10:45 AM   #1
Soffit vents tacked not screwed, sagging
It looks like the contractors that built my home (12 yrs ago) used tacks to secure the soffit vents.
After twelve years, they seem to be sagging on the edges. I've also noticed that some don't seem to have enough tacks.
Suggestions? Use screws? Re-tack, leave it? Worried about insects. There seems to be screen behind them but if they are not secure I have to imagine insects can easily get past.
As you can see, some are high up. I am unable to get up to them close.
Thanks,
J
Soffit vents tacked not screwed, sagging-20120704_01.jpg   Soffit vents tacked not screwed, sagging-20120704_02.jpg   Soffit vents tacked not screwed, sagging-20120704_04.jpg   Soffit vents tacked not screwed, sagging-20120704_05.jpg   Soffit vents tacked not screwed, sagging-20120704_06.jpg
johnbravos is offline   Reply With Quote
Old 07-04-2012, 10:56 AM   #2
Tom Struble's Avatar
Rewards Points: 2,002
well you can try wishing them back up but that usually don't work
Tom Struble is offline   Reply With Quote
Old 07-04-2012, 11:36 AM   #3
the Musigician
DangerMouse's Avatar
Be nice Tom...
I'd get/use/borrow/rent a tall ladder and add screws, yes. They should be fine after that.
DM
Old 07-04-2012, 12:03 PM   #4
Strange. Tried pushing on the corners with a yard stick. There is no give to them. That is, they don't sit flat, which is why they appear to be sagging. Apparantly they are not. Whatever is behind them is preventing them from lying flat on the soffit, possibly the screen. I will have to pull a few off and see how these were installed.
Old 07-04-2012, 01:59 PM   #5
kwikfishron's Avatar
Rewards Points: 418
Thatís probably because thereís a layer of crud between the vent and the soffit which wont allow you to push them back.
They look stapled too me. If you or someone has to get up there anyway Iíd remove them and inspect the screens and make sure all is clear for good airflow.
Go easy on them, it doesnít take much to destroy those cheesy things. Use stainless steel screws when re-installing.
If it was me Iíd paint them to match the soffit. Itís not like those vents at an architectural detail you want the world to see.
kwikfishron is offline   Reply With Quote
Old 07-04-2012, 04:45 PM   #6
Originally Posted by DangerMouse View Post
Be nice Tom...
DM
i thought i was?
Old 07-05-2012, 04:38 PM   #7
Rewards Points: 254
Just replace them while you are up there ( they are $2-3 each) and add flat head s.s. screws in each hole. The staples are common with the shortcuts workers are doing when building a house.
pwgsx is offline   Reply With Quote
Old 07-05-2012, 06:30 PM   #8
Rewards Points: 13,458
Flat head screws?
Not the best look for that job.
Think about using painted hex head gutter screws. I put them in all the time with a magnetic 1/4 bit in a impact drill driver.
Old 07-06-2012, 10:16 AM   #9
Rewards Points: 254
Originally Posted by joecaption View Post
Flat head screws?
Gutter screws?? Really, so the head sticks out- thats not a good look at all!!
Flat heads look just......there are many types of flat head screws. These are what I used, smaller of course but you get the idea. Lays nice and flat and looks great after you paint the vent and screw heads, which should be done anyway. Who wants to look at a unpainted vent??
Old 07-06-2012, 10:45 AM   #10
the Musigician
I believe he meant PAN head, not screws for flat head screwdrivers....
DM
Hidden Soffit Vents Mucluk Building & Construction 4 01-26-2012 08:15 AM
Put in more soffit vents? John_W Roofing/Siding 0 09-10-2011 09:04 PM
Taking off Soffit Vents to clear insulation Mishof Roofing/Siding 15 09-03-2011 04:01 AM
Do I need to replace soffit vents?? And other roofing questions. kennykenny Roofing/Siding 5 04-17-2011 09:22 AM
soffit vents federer Roofing/Siding 13 08-26-2010 10:44 PM
