Soffit Vents Installed? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-22-2008, 01:04 PM   #1
Soffit vents installed?
Hello - We had a new roof and gutters installed last fall. Early summer I noticed the attic vent fan was running a lot - thermostat was set for around 110F - old fan & the motor burned out - I installed a new fan, thermo @ 115F & it also seems to run a lot. Reading on line - I know the roofers added a ridge vent - I can see that - but sitting in the dark attic I only see random light coming threw where soffit vents should be. Other than removing the continuous soffit covers is there a way to tell if they 'forgot' the soffit vents? And how much soffit venting do you need? The attic floor is 40X20 ft. The temperature in the attic seems to be about 20+ degrees hotter than the outside temperature.
Thanks.
dkat is offline   Reply With Quote
Old 07-22-2008, 09:13 PM   #2
the roofing god's Avatar
Send a message via MSN to the roofing god
the light is an indication of vented soffits,usually a 8" x 16" hole every 4 ft is good,or a 1 1/2" continuous slot,attic only 20 degrees hotter than outside is not bad at all
"If it`s worth doing,It`s worth doing right!!"
www.ADVANCEDROOFINGNEWYORK.com
the roofing god is offline   Reply With Quote
Old 07-23-2008, 07:55 PM   #3
Grumpy's Avatar
Rewards Points: 552
Send a message via AIM to Grumpy Send a message via MSN to Grumpy Send a message via Yahoo to Grumpy
You have a fan and a ridge vent? That's the problem right there! www.airvent.com www.rollvent.com
What is happenign is ventilation short circuit. Think like a fan for a second. When the fan is on what is it supposed to do? Suck air. The fan chooses the path of least resistance. It should suck air from the eave intake but if there is a closer source for air it will take it from that source. Simple laws of physics.
So what is happening is the fan is sucking air in throught he ridge vent that is probably 1-2' away from it. It then exhausts that air and sucks it right back in through the ridge vent. YOu have a nasty constant loop going on... and a roofer who doesn't understand the dynamics of attic ventilation.
Remove the ridge vent OR remove the fan and check your overhangs to make sure you have proper intake. You may have to remove one or two vented soffit panels just to make sure the installers actually cut openings. There are rules of thumb at the websites I posted, and as TRG posted above continuous intake is better.
-Grumpy http://www.illinoisroofinspections.com
The information found in this post is not to be considered legal advice. The author of this post takes no responsibility for any losses that occur. Use at your own risk.
Grumpy is offline   Reply With Quote
Old 07-23-2008, 08:08 PM   #4
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
A note on Grumpy's post. RV is meant as an outlet. The fan sucking ir into it has probably clogged the vent filter by now. Ed and others have posted pics of these clogged vents. You may have to replace the RV if you get rid of the fan. Without a detailed inspection by a pro, it's hard to advise you fully.
BTW, was there any light coming from the RV?
tinner666 is offline   Reply With Quote
Old 07-24-2008, 06:29 PM   #5
Thanks.
20* warmer in the attic than the external temperatures is not out of line and actually is quite cool.
I believe that the thermostat needs to be set around 130*, or else the motors will burn out.
Ed
Ed the Roofer is offline   Reply With Quote
Old 07-24-2008, 06:31 PM   #6
good catch on the rv existing,I answered late evening,early am,and didn`t pick up on the rv being there
Old 07-24-2008, 06:42 PM   #7
Set the thermostat to 130* or else it will burn out the motor.
Poke a scratch awl through the vent perforations in the aluminum soffit panels to see if the wood was cut away.
40 x 20 = 800 square feet
Minimum Total NFVA = 800 divided by 300 = 2.667 square feet
Convert to Square Inches = 2.667 x 144 sq in = 384 square inches of venting needed. Vented Soffit Panels deliver between 6 sq in to 9 sq in per square foot of vented panel, if they are not clogged or painted over and if the wood is completely cut away from the old wooden existing soffits before the aluminum panels were installed.
The better and more useful formula requires the 800 sq ft to be divided by 150, which would require you to double the amount of ventilation required. The 1/300 formula is only if you have a balanced ventilation system, with 1/2 from intake and 1/2 out through the exhaust.
Nearly everyone needs much more than they currently have.
Thanks.
Please read the inserted notes in your quote.
Ed
Old 07-25-2008, 10:45 AM   #8
Updateing - no soffit vents
Thanks for the Info -
The company that did the roof also did the gutters - which have some issues & called for a fix on them (the gutters) - new guy w/ the company, he's there 'fixit guy' - short story - asked him about the roof & vents. He crawled in the attic to the soffits, no vents cut.
The guy said they'd have to take off all the soffit vent covers & cut holes & he couldn't make that call. He'd need to talk to the owner.
Once the vents are cut - I should cover up the gable vents? And no fan.
And a roofer should know this.
ps - thanks Grumpy - I have the Roll Vent! (& specs to give the guy!)
Soffit Vents Sammy Building & Construction 9 07-07-2008 06:31 PM
Insulation Batt Blocking Soffit Vents mikebal Roofing/Siding 8 07-05-2008 04:58 PM
Blocked Attic Soffit Vents on North Side - How to Improve Venting Jes Roofing/Siding 5 05-06-2008 09:35 AM
Icicle forming out of soffit vents??? GearHd6 Building & Construction 23 12-25-2007 03:00 PM
Missing soffit vents glenn60 Building & Construction 6 04-14-2006 02:25 PM
