Soffit Vents Blocked - Trying To Fix From The Outside - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-22-2013, 12:42 PM   #1
Rewards Points: 159
Soffit vents blocked - trying to fix from the outside
I noticed some gray type mold forming in the attic, and it was damp this past winter.
I fixed the ridge vent last year (removed, cut the gap wider and reinstalled)
I pulled down the soffit and now see jammed insullation.
It is jammed so tight the foam vents are pushed tight to the roof.
From the outside of the house remove soffit.
Push insulation in away from soffit to clear the opening
Install blue foam pieces in each opening (only everyother now)
Re-install soffit, except each piece will have a vent strip.
theedudenator is online now   Reply With Quote
Old 07-22-2013, 02:31 PM   #2
MarginallyQualified
Rewards Points: 2,464
Good detective work.
Old 07-23-2013, 12:54 AM   #3
Rewards Points: 159
I also pulled the ridge vent off, as it was nailed down tight.
Got a decent rush of hot air as we pulled if off.
I installed a new baffle type system. I guess supposed to be an upgrade from the typical cobra vent.
Old 07-23-2013, 08:26 AM   #4
Rewards Points: 252
The mesh type ridge vents are often installed incorrectly and don't allow enough airflow. The baffle type are definitely a better system. Unfortunately some contractors don't understand the products they are installing, so they end up being installed incorrectly.
shazapple is offline   Reply With Quote
Vinyl Perf Soffit over Wood - No Vents nickelshine Roofing/Siding 18 05-29-2012 10:12 AM
Hidden Soffit Vents Mucluk Building & Construction 4 01-26-2012 09:15 AM
Ventilation - Opposing gable, limited soffit + box vents = Screwed up? darlingm Roofing/Siding 1 09-07-2011 11:13 AM
Knee wall w/ soffit vents no ridge vent -- seal soffit vents? tblaz Roofing/Siding 1 04-24-2011 05:12 PM
Blocked Attic Soffit Vents on North Side - How to Improve Venting Jes Roofing/Siding 5 05-06-2008 10:35 AM
