Soffit Vents - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 08-26-2010, 04:51 PM   #1
Rewards Points: 956
Exclamation
soffit vents
So as some of you may know i am getting my roof replaced. in terms of ventilation we are thinking about going with box vents on the steeper slope side. but are these soffit vents adequate?
federer is offline   Reply With Quote
Old 08-26-2010, 04:57 PM   #2
Doing This Way Too Long
Rewards Points: 532
Those are more than likely covering up an original soffit material. It all depends on what it looks like underneath that aluminum that counts.
OldNBroken is offline   Reply With Quote
Old 08-26-2010, 05:08 PM   #3
Rewards Points: 956
crap so i gotta tear them off and see
Old 08-26-2010, 05:18 PM   #4
Rewards Points: 532
no, start by just removing an easy one to see what's under it (technically, above it but don't start with me). Could be open, could be solid wood or plywood. If it's open it looks like you are adequate. If there is an original soffit under it you need to make sure there are adequate openings in it at or close to the perforated soffits you have there. Good news is you can just hole-saw them if you have to. A fine-mesh screening stapled over the holes wouldn't hurt to keep all the really tiny critters out. Then just re-install the aluminum.
edit: and, of course, make sure someone didn't blow insulation into the soffits. If so, you just got yourself another fun project to add to the list.
Old 08-26-2010, 05:55 PM   #5
Rewards Points: 956
thanks for the tip. i am actually getting estimates on putting in new insulation as well. fiberglass is better than cellouse right
Old 08-26-2010, 06:04 PM   #6
Rewards Points: 532
I'm a roofer and metal guy, not an interior insulation guy, sorry. I'm not sure what forum one would post that question in here.
Old 08-26-2010, 07:24 PM   #7
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
Fiberglass bad - cellulose good.
seeyou is offline   Reply With Quote
Old 08-26-2010, 08:03 PM   #8
Rewards Points: 956
why is that
Old 08-26-2010, 08:50 PM   #9
Registered User
Rewards Points: 4,902
Fiberglass is only bad if you live where it is cold....... or hot........ or mixed. Seeyou's ball....
Your soffit vents are the slots, similar to the holes, maybe a tad better. If the holes, and 18" deep soffit you get 7sq.in.NFVA per ft. of perforated. So you are getting= 7NFVA/3' = 2.34 sq. in. per ft. You should have 9NFVA per ft. That would be with ALL vented, no solids.
http://files.buildsite.com/dbderived...rived92755.pdf
http://www.airvent.com/homeowner/pro...it-specs.shtml
Be safe, Gary
Old 08-26-2010, 09:39 PM   #10
Rewards Points: 956
Be safe, Gary
thanks Gary. the link refers to ridge vents though. i dont thnk i can install a RV with my flat roof. it would have to be box vents.
edit-instead of using insulation what if i got like the aerogel stuff and put a sheet of it to cover the entire attic space
Old 08-26-2010, 10:39 PM   #11
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
Cellulose is more effective at stopping infiltration. With the same R values, a building insulated with cellulose will out perform a fiberglass batt insulated building due to less air movement. Chopped fiberglass is better than batt for ceilings.
Old 08-26-2010, 11:12 PM   #12
Rewards Points: 956
oh sorry i meant blown in fiberglass not batts
Old 08-26-2010, 11:17 PM   #13
Registered User
Wow, that is something! First time I ever heard of it! Not familiar with it. How much does it cost? Sold locally?
I wonder why they did not vent every bay in a flat roof.......
Gary
Old 08-26-2010, 11:44 PM   #14
Rewards Points: 956
really? i thought they have been around for some time.....maybe i am thinking of something else
No soffit vents needed? MikeNY Roofing/Siding 4 08-24-2010 05:30 PM
Installing Soffit vents w/finished attic Nathan0115 Roofing/Siding 6 06-04-2010 10:05 PM
Boarded over soffit vents Jim F Roofing/Siding 6 04-21-2010 11:10 PM
Soffit vents on older houses with "curved" ceilings Labman101 Roofing/Siding 2 02-07-2010 11:33 PM
Soffit Vents Sammy Building & Construction 9 07-07-2008 07:31 PM
