Soffit Venting On Old House - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-31-2010, 10:43 AM   #1
Ord
Soffit venting on old house
Hello,
we recently moved into a 100 year old home, and are starting to do some work on it. We were going to put some more insulation in the attic, but first we wanted to make sure the venting was correct. It is a 1 1/2 story, all the second floor rooms have 4 ft knee walls then 5ft of sloped ceiling. So, from in the attic I cannot reach down to the soffit.
A lot of loose fill insulation has fallen down between the rafters, in some cases filling them completely. We tried getting it out with a shop vac, but it just plugs up after a few seconds.
On the outside there are vented aluminum soffits, but after removing a few I see that there is solid wood underneath with no vents. The soffits are not horizontal like I usually see them, they are pitched like the roof, it seems like they are just nailed to the underside of the rafters.
Will I have to remove all these boards, let the insulation fall out, then replace them with vented pieces, or is there a better way?
Also, is there any problem with having the soffits sloped like this?
Thanks!
Ord is offline   Reply With Quote
Old 07-31-2010, 12:24 PM   #2
Registered User
Rewards Points: 5,514
Balloon framed, this will get you started: http://www.wag-aic.org/1999/WAG_99_baker.pdf
Solution: http://www.rd.com/how-to-seal-attic-...icle18158.html
More to come......
Be safe, Gary
Weird wiring in house fdmillion Electrical 13 06-14-2013 06:49 PM
Questions about jacking up house to replace rotted rim/sill SolidStateS15 Remodeling 10 03-22-2010 11:43 AM
Addition Question: venting roof/crawlspace supton Building & Construction 6 01-22-2009 06:33 PM
Moving a House 70 miles- Practical? GOTHICrevivalRULES Building & Construction 19 11-27-2008 08:58 PM
Soffit Venting for Aluminum Sofits kevn83 Roofing/Siding 3 07-23-2008 08:05 PM
