Soffit Venting - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 06-12-2013, 01:42 PM   #1
soffit venting
Hello,
I want to add some soffit intake vents. I noticed the round plastic and the grille vents. If I used these how can I make sure when I cut into the existing aluminum soffit that I won't hit a rafter?
markharmon is offline   Reply With Quote
Old 06-12-2013, 01:48 PM   #2
Rewards Points: 2,494
Locate where the rafter ends are and then do not cut hole in the soffits at that location
hammerlane is offline   Reply With Quote
Old 06-12-2013, 02:57 PM   #3
Rewards Points: 12,802
Got a picture?
Why not remove the soffets that are there now and replace with vented soffits.
Sure it's not soild plywood behind those soffits?
Old 06-12-2013, 03:49 PM   #4
Originally Posted by joecaption View Post
Got a picture?
its possible there is plywood there. Not sure yet. Can I just cut some of it out then add the vented soffit?
Old 06-12-2013, 10:14 PM   #5
Rewards Points: 140
drill a 1/2" hole. then stick a bent piece of wire up there and probe around.
Fix'n it is offline   Reply With Quote
Old 06-13-2013, 08:00 AM   #6
Well the vented soffit cover will do no good unless a hole is cut so yes you will need to make some cuts.
Are you adding "more" vents or does your current soffit have no venting at all?
Old 06-13-2013, 02:39 PM   #7
Adding more. The grill type that was shown in your picture. How big of a cut needs to be made if there is plywood. Then you screw the grill into the existing non vented soffit?
Old 06-13-2013, 09:48 PM   #8
Roofmaster
Rewards Points: 2,172
The only passive venting that really does much of anything is continuous vented soffit in concert with high flow continuous ridge venting. What you are doing is really not worth it, in my experience
I recommend and have white aluminum continuous eaves ventilation, and good continuous ridge ventilation, and it really works well. Plastic soffit builds up a static charge from the wind and attracts atmospheric dirt fast
cathedral ceiling soffit venting david palumbo Insulation 1 06-27-2011 08:54 PM
Could lack of soffit venting increase indoor negative air pressure? creamaster Roofing/Siding 1 03-07-2009 02:27 PM
Soffit venting question dat5574 Roofing/Siding 2 03-03-2009 11:21 AM
Soffit venting vs. DCI Smart Vent JDPII Roofing/Siding 1 02-28-2009 09:42 PM
Blocked Attic Soffit Vents on North Side - How to Improve Venting Jes Roofing/Siding 5 05-06-2008 10:35 AM
