Soffit Venting - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 08-22-2011, 01:35 PM   #1
Rewards Points: 39
soffit Venting
I have a cape cod without a lot of soffit to begin with. Last year I had condensation in my attic after a new roof was installed with a ridge vent. There are still existing vents at the peaks along the sides of the dormers.
Today I decided to dig in and see what a lot of people have been telling me. I got brave and ripped out a piece of the soffit and verified there was plywood underneath it. Also cleaned out the insulation that was stuck above it from in the attic. Now I just don't know what to do. To follow this process it would seem I have to ruin all the so called ventillated soffit. Does anyone have any ideas?
soffit Venting-dsc_3598.jpg   soffit Venting-dsc_3599.jpg   soffit Venting-dsc_3600.jpg   soffit Venting-dsc_3601.jpg   soffit Venting-dsc_3602.jpg
Typ0 is offline   Reply With Quote
Old 08-22-2011, 03:37 PM   #2
kwikfishron's Avatar
Rewards Points: 410
You can remove and reinstall the aluminum soffit without destroying it.
First open up the end of the channels and slide the piece out. The soffit should be stapled although it doesn’t look like it in the picture. If so remove the staples and slide the soffit out, drill your holes then reinstall the soffit.
kwikfishron is online now   Reply With Quote
Old 08-22-2011, 09:20 PM   #3
You can remove it. You might ding it a little. I just did this same project. After you get it out, cut out as much of the wood with a sawsall or remove it entirely. it can be done.
beerdog is offline   Reply With Quote
cathedral ceiling soffit venting david palumbo Insulation 1 06-27-2011 07:54 PM
Too Much Soffit Venting? atw58 Roofing/Siding 2 05-16-2009 08:19 AM
Could lack of soffit venting increase indoor negative air pressure? creamaster Roofing/Siding 1 03-07-2009 01:27 PM
Soffit venting question dat5574 Roofing/Siding 2 03-03-2009 10:21 AM
Soffit venting vs. DCI Smart Vent JDPII Roofing/Siding 1 02-28-2009 08:42 PM
