Soffit Upgrade And Insulation Clearance - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-13-2013, 01:40 PM   #1
Soffit upgrade and insulation clearance
My roofer put up VentSure Heat & Moisture at the ridges and so I went around looking at the existing soffits for intake balance. Unfortunately, I don't think they did an honest NFA calculation; we have existing bird block hole soffits which if generous, are about 3" of NFA each. They installed 18" per foot NFA VentSure.
For example, in one section, about a 26 foot run, that would be around 450" NFA of VentSure and there are 37 holes (111" NFA). That's a big discrepancy. I'm sure they looked up, saw existing holes and called it done.
So two questions. First. The existing holes need to be expanded into 16x6" or 16x8" rectangle soffits to get closer to a balanced NFA. How hard is that to do when in places it can't be accessed from the inside? Cutting through the bird block and getting out the existing screening looks like a tough job (especially on tall ladders). I'm actually wondering if installing something roof-side like SmartVent might be easier.
And two. Insulation clearance. When I talked to the roofer about it the other day, when I was alarmed that a lot of the existing insulation seems to be butted up against the soffits. He said that 3/4" of clearance is all that is needed for the airflow. If there are no soffit baffles in place (which there aren't) is that reasonable?
Thanks in advance for any advice.
eelpout is offline   Reply With Quote
Old 07-14-2013, 09:23 AM   #2
Rewards Points: 646
3/4" is okay, 1" is better. Baffles should be installed to maintain that airspace.
Its not too hard to cut plywood/wood soffits from underneath, even easier if your just expanding the hole. Just use a jigsaw or sawzall and take your time, if ladder stability is a worry for you use a set of standoffs, they make a huge difference.
PatChap is offline   Reply With Quote
Old home insulation upgrade during remodel? mnhockeydude Insulation 1 07-07-2013 08:26 AM
Exterior walls need upgrade in insulation xjsparky Insulation 7 06-22-2011 08:43 PM
Garage insulation - to replace or not, and related questions DaveinGA Remodeling 6 12-20-2009 10:25 AM
upgrade with Foil faced insulation? Chemist1961 Building & Construction 3 12-11-2009 05:27 PM
Did you get a resi. insulation upgrade? Yoyizit HVAC 0 06-12-2009 08:31 AM
