Soffit Too Narrow, Gutters Leaking, Rot Everywhere - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 04-27-2013, 02:16 PM   #1
Post
Soffit too narrow, gutters leaking, rot everywhere
I don't know which to tackle first. My gutters sag in the middle, some have come away from the studs, water leaks all over the place. I've paid 3 contractors who didn't fix the problems. What soffit vents exist, are partially covered by external trim and while investigating in the attic, the openings are just rectangle holes, less than half the size of the vents, with lots of sharp pieces sticking everywhere. My front entry has rotted, window trim has rotted, on the front and back of my house. My house faces due North, no porch or cover over my front door, 2 story front with palladium window over the entry which includes door, side panels and transom over the door.
My stoop has come away from the house which is another matter for a later post.
Any ideas?
geekgirl is offline   Reply With Quote
Old 04-27-2013, 02:23 PM   #2
Rewards Points: 2,238
Post some pictures!
rossfingal
rossfingal is offline   Reply With Quote
The Following User Says Thank You to rossfingal For This Useful Post:
r0ckstarr (04-27-2013)
Old 04-27-2013, 02:51 PM   #3
funfool's Avatar
Rewards Points: 534
Toss up the pics, 1 picture is worth a thousand words.
If you have improperly installed gutters, and leaking, they just need to come down and be properly hung or replaced as needed.
Water is the #1 enemy of a home, need to take each individual case and eliminate the source of the water to to stop the rot from coming back. Ans of course you want to remove and replace all rotten wood before it becomes a bigger chore.
If outside window trim is rotting, is good chance it can be getting into your walls and causing bigger issues you have not seen yet.
And please add your location to your profile. It is a big help to others to know what weather conditions you put up with, are you on a coast with salt water, down south with blistering sun, up north with ice and snow?
funfool is offline   Reply With Quote
Old 04-27-2013, 03:22 PM   #4
r0ckstarr's Avatar
Rewards Points: 1,978
Yep, let's see some pictures showing everything you're talking about.
r0ckstarr is online now   Reply With Quote
Tags
gutters , rot , soffit
Water/Ice on fascia leaking into sofit and house da_man Roofing/Siding 1 02-07-2011 04:22 PM
Leaking Gutters fripster Roofing/Siding 5 02-13-2010 09:25 PM
How to gently remove (aluminum) soffit? superfly Roofing/Siding 1 09-06-2009 10:15 PM
Help with installing aluminum soffit and fascia Boontucky Roofing/Siding 3 09-01-2009 08:47 PM
Leaking gutters KTMMIKE General DIY Discussions 1 09-13-2005 12:24 PM
