Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing/Siding
Old 05-04-2011, 08:44 PM   #1
Soffit materials
Hey all. New guy here, the name's Ben. First post here after a whole lot of reading!
I live in the midwest (think St Louis, MO / Paducah Ky). My house was built in the 70's and has wood soffit and fascia. There are several places along the eaves (gutter edges) where the fascia and soffit is rotted/peeling/falling apart. I am hoping to be getting a new roof in the next few weeks and am planning on replacing the soffit and fascia along the gutter edges on my own. I know all about the aluminum and vinyl options but want to keep it as close to the original as possible. I'm thinking cedar 1x6 for the fascia but didn't know what to use for soffit. I have seen a recently constructed sub-division that had some sort of 1/4" soffit board in which half of the board was covered in 1/4" holes for venting. I've been scouring the net for info on this material but have came up empty. The board seems like it could be a wood material, or maybe a fiber/cement based board??? I'm not entirely sure.
Anyone have suggestions on what type of board/wood/other I could use for my soffiting?
Thanks in advance everyone! Sorry for the lengthy post! Looking forward to being a part of your community.
Dawson is offline   Reply With Quote
Old 05-04-2011, 08:54 PM   #2
Framing Contractor
Soffit materials
They do make a perforated fiber cement soffit. I have used it, but do not like the results. How about a 3/8 fir plywood soffit? It can be stained to match the cedar, and a continuous aluminum vent can be used.
sixeightten is offline   Reply With Quote
Old 05-04-2011, 09:07 PM   #3
Soffit materials
I can't find any information on the fiber cement soffit at any of the BBS (Menards, HD, Lowes). Would 3/8" be minimum for fir? I'm assuming it's resilient like cedar? What is the continuous aluminum vent? Like a drip edge vent???
Old 05-04-2011, 09:11 PM   #4
Framing Contractor
Soffit materials
Continuous aluminum vent is 2"x10' strips of punched aluminum. We generally run a 2" strip of fir soffit, the 2" aluminum vent, and then the remainder is fir as well. Most of our soffits are 12" so that would mean the back strip of fir is about 8". Framing is installed first to give you something to attach the soffit to.
Old 05-04-2011, 09:16 PM   #5
Framing Contractor
Soffit materials
It looks like this
Old 05-04-2011, 09:20 PM   #6
Soffit materials
Thats a good idea.. Thanks.
Where can I find more info/price on the fiber cement? The less I have to cut and build, the better I'll like it.
Old 05-04-2011, 09:23 PM   #7
Framing Contractor
Soffit materials
Call a few lumber yards in your area. This is basically what you are talking about.
Old 05-05-2011, 12:00 AM   #8
Soffit materials
Yes, that's the material I've seen only without as much woodgrain pattern.
Thanks for the info, I'll see what the local yard has.
Old 05-05-2011, 01:07 AM   #9
Moderator
Soffit materials
I wouldn't use the f.c. products here; http://www.certainteed.com/resources...tspecsheet.pdf
They only have a -7 NFVA per ft. and that's 12" deep. The vent should be located next to the fascia board for optimal air-flow, pp. 616: http://books.google.com/books?id=Z8a...0vents&f=false
The box stores carry the double-direction louvered continuous metal strips that help stop the snow/rain coming in to the attic with the wind up the house wall. If calculating your NFVA with 150/ attic area and have a ridge vent with 18 NFVA per ft., you'll need 9 NFVA as the box store vent is for each side of the gable soffits to match #'s. http://www.airvent.com/homeowner/pro...it-specs.shtml
Gary
Clothes taking longer to dry?
Old 05-05-2011, 02:35 PM   #10
Mod
kwikfishron's Avatar
Soffit materials
If the soffit is going to paint I use Breckenridge Plywood in conjunction with the continuous vent that sixeigtten shows in post #5.
Breckenridge is an exterior grade clear plywood with a slightly rough surface. If done right it’s a real clean look.
I only use Hardi Soffit when they make me.
-NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State.
kwikfishron is offline   Reply With Quote
Vinyl Perf Soffit over Wood - No Vents nickelshine Roofing/Siding 18 05-29-2012 10:12 AM
Basement Fireblocking within HVAC Soffit ssmith147 Building & Construction 3 12-31-2009 07:36 AM
How to gently remove (aluminum) soffit? superfly Roofing/Siding 1 09-06-2009 10:15 PM
Help with installing aluminum soffit and fascia Boontucky Roofing/Siding 3 09-01-2009 08:47 PM
Another Ridge Vent, Gable vent and soffit question (??) davco Roofing/Siding 2 05-01-2007 12:14 AM
