Soffit And Fascia Install - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 11-14-2011, 11:37 AM   #1
Soffit and Fascia Install
My house looks a lot like the one pictured here.
The paint on the exposed rafters is old and flaking off, but the rafters are generally in good condition. The siding on the house is cement stucco.
Can I install F-channel against the stucco and F-channel to the bottom/ends of the rafters? Or do I need to install a sub-fascia board to the ends of the rafters first?
My concern is that any sub-fascia board would push the finish fascia beyond the end of the drip-edge flashing already installed under the roof shingles. Can I use two opposing f-channels and then a finish fascia to cover the rafter ends? I'm just not sure if the rafter f-channel would require additional support between rafters.
One option would be to install some 1X pressure treated blocking at the ends of the rafters to nail the soffit into.
Another option is to trim off 1" from the tips of the rafters with a sawzall and put up a continuous strip of 1X Pressure treated as a nailing strip. This is the option I'm leaning towards.
Finally, are there any soffit/fascia systems that are available at the big box stores you have used and can recommend?
Thanks!
atxjoe is offline   Reply With Quote
Old 11-14-2011, 05:01 PM   #2
I stopped by Big Box #1 and they don't stock this stuff, no options for special order. Big Box Chain #2 I can special order but only by the carton, so I'll get about 2X the material I need.
Any suggestions on where I can get this stuff would be great. It doesn't seem like a hard DIY project if I can source the material.
I'm looking for this stuff.
Old 11-14-2011, 05:37 PM   #3
MJW
Go to a lumber yard.
MJW is offline   Reply With Quote
Old 11-14-2011, 05:53 PM   #4
kwikfishron's Avatar
Rewards Points: 190
Lowes stocks the stuff.
Look at this for the installation. http://www.vinylsiding.org/publicati...ion_Manual.pdf
kwikfishron is online now   Reply With Quote
Tags
fasica , soffit
Question about replacing fascia and soffit paneling creamaster Carpentry 2 03-31-2010 10:01 PM
Vinyl soffit and fascia msyv Building & Construction 7 09-13-2009 11:21 PM
Help with installing aluminum soffit and fascia Boontucky Roofing/Siding 3 09-01-2009 08:47 PM
Fascia cover filled with water/ice causing leaks brianbh Roofing/Siding 10 02-11-2008 08:34 PM
Aluminum Soffit and Fascia Installation... MoparAutoworks Building & Construction 1 12-17-2006 08:46 AM
