Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 12-31-2010, 08:42 AM   #1
soffit, fascia, and gutters
i am planning on installing aluminum soffit, fascia and gutters this summer
which should i do first? any tips when doing them?
thanks!!
awdblazer is offline   Reply With Quote
Old 12-31-2010, 08:52 AM   #2
the Musigician
DangerMouse's Avatar
Fascia, then soffit, then gutters is how I'd do it.
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Old 12-31-2010, 10:23 AM   #3
Soffit then fascia then gutters. If large roof area and/or steep, better to install 6" rather than 5" gutter.
larryb is offline   Reply With Quote
Old 12-31-2010, 12:48 PM   #4
the Musigician
Mine would have been rather impossible in that order, since the bottoms of the fascia hold my soffits.....
DM
Old 12-31-2010, 01:59 PM   #5
Soffit, fascia then gutters. Measure the soffit so that you can nail it tight to the inside of the fascia board. Then it will be easy for you to wrap the fascia metal under the fascia board so that you are able to cover up where you nailed in the soffit.
DM - how did you get the correct measurement for a bend that would be sufficient for the fascia? Was it a pain to get the soffit in?
BamBamm5144 is offline   Reply With Quote
Old 12-31-2010, 02:11 PM   #6
the Musigician
Nope, I used aluminum fascia, aluminum F-channel on the wall and vinyl soffit connected piece by piece and slid down the length.
DM
Old 12-31-2010, 04:03 PM   #7
MJW
Yep, then they are all nailed/stapled. Seen plenty of soffits blow out with little wind because they were just held up by the fascia.
I don't use coil for fascia though. Only steel pre-made fascias.
MJW is offline   Reply With Quote
Old 12-31-2010, 04:41 PM   #8
Framing Contractor
DM
How can he do it in that order?
Existing fascia is on already. Where I'm from the new soffit gets nailed to the bottom of the fascia and the F-channel gets nailed to the wall. After that the fascia gets wrapped with a L-bend at the bottom covering the soffit. Gutters last.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 12-31-2010, 08:18 PM   #9
Moderator
If venting the attic with this, use continuous metal venting close to the fascia board for keeping the rain and snow from entering rather than the positive air flow near the house wall. If perforated, make sure to use enough for a balanced venting system.
Gary
Clothes taking longer to dry?
Old 01-03-2011, 07:27 PM   #10
I just had soffit and aluminum coil fascia done this summer, and new gutters. They put the soffit on first and put a bend of about 1-1/2" on the aluminum coil to cover the soffit attached with small stainless steel nails the color of the aluminum coil and soffit. The main tip I could give you is when they metal break the fascia, have them put that extra bend in it to prevent wrinkling on the gable ends and make sure they get it under your drip edge well. On the gutter, I used the brackets and screw system which don't show so you don't have to use gutter spikes and it makes for a cleaner, neater look.
guest is offline   Reply With Quote
Old 01-03-2011, 07:36 PM   #11
also I forgot to mention, I used the normal size gutter but went with the 6" downspouts. No problems and everything looks really nice. good luck!
Old 01-03-2011, 08:32 PM   #12
Tom Struble's Avatar
6'' downspout
actually it's doable in any order
Tom Struble is offline   Reply With Quote
Old 01-03-2011, 09:02 PM   #13
It's the larger downspouts, helps with getting the water out quicker.
Gutters and Decorative Trim on Fascia paulyg Roofing 12 07-27-2010 03:54 PM
Question about replacing fascia and soffit paneling creamaster Carpentry 2 03-31-2010 10:01 PM
Vinyl soffit and fascia msyv Building & Construction 7 09-13-2009 11:21 PM
Rotted Soffit and Fascia boyfly Carpentry 1 05-08-2009 11:12 PM
Advice on installing gutters on slanted fascia notfromaroundhere Roofing 3 12-27-2008 05:34 PM
