Soffit - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-05-2012, 09:31 AM   #1
Soffit
Can you put news plastic soffit up over wood with out removing the wood and what about vents
PeggyKuras is offline   Reply With Quote
Old 07-05-2012, 11:37 AM   #2
Rewards Points: 14,306
Why are you trying to do all that work without instaling vented soffit? With out vents in the soffit any vents on the roof are about useless.
A picture, and far more info sure would be a big help.
Your really going to also wrap the fashias with coil stock to do this right. It holds up the soffits and covers the exposted wood so there's no more painting.
Old 07-06-2012, 11:13 AM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,554
+1 on a picture.
Yes you can put up new soffit over the wood but make sure it is clear and vented if the previous roof was vented.
Old 07-07-2012, 03:36 AM   #4
to the original poster...
did you mean new plastic soffit?. I on't know if I am missing something here.
Please put up a question in a more easy to understand way
caliberroofs is offline   Reply With Quote
New siding up to existing soffit jtchavez Building & Construction 18 03-25-2012 09:48 AM
Replacing soffit tucked behind brick veneer. Queequeg152 Building & Construction 3 02-25-2012 07:10 AM
Hidden Soffit Vents Mucluk Building & Construction 4 01-26-2012 08:15 AM
How to gently remove (aluminum) soffit? superfly Roofing/Siding 1 09-06-2009 09:15 PM
Help with installing aluminum soffit and fascia Boontucky Roofing/Siding 3 09-01-2009 07:47 PM
