So I Told The Inspector..... - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 08-24-2010, 08:41 AM   #1
the Musigician
DangerMouse's Avatar
So I told the inspector.....
I got the goop to stick the roof vent boot to the roof, and he says "Why? You don't need that.... just shove the thing under the shingles, it'll be fine."
HUH???
DM
Old 08-24-2010, 08:55 AM   #2
fabrk8r
fabrk8r's Avatar
If shingles are cut correctly and lifted carefully you can install flashing without worry of leakage.
I always use a little blackjack though, just to be sure.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 08-24-2010, 01:04 PM   #3
Rewards Points: 978
can you hire an inspector from your state to come out and inspect a replacement roof
federer is offline   Reply With Quote
Old 08-24-2010, 01:12 PM   #4
Enough is Enough
H. A. S.'s Avatar
If it's done right, you don't really need it. I always use a little anyway.
H. A. S. is offline   Reply With Quote
Old 08-25-2010, 07:38 AM   #5
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
No goop needed. Flashing gets weaved into the shingles. 1/2 on top, 1/2 under them.
tinner666 is offline   Reply With Quote
Pergola - can you believe what the building inspector told me Italgrl Building & Construction 35 09-05-2014 12:00 PM
Newbie with a Building Inspector problem Germain Remodeling 4 11-08-2009 06:33 PM
Angry Electrical Inspector... theatretch85 Electrical 10 05-24-2009 08:39 AM
look at this mess! MsJoanD Project Showcase 14 08-29-2008 07:04 PM
How is electrical inspector doing the inspection... KUIPORNG Electrical 2 08-15-2006 08:46 PM
