Snow Melt In Gutters ? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 12-22-2013, 08:32 AM   #1
Rewards Points: 236
snow melt in gutters ?
i have thought of this in the past. but now that i actually own gutters, i don't have this problem. but looking at the large ice dams in my neighbors gutters, got my to rethinking about it. would putting any kind of ice melter in gutters cause any unwanted issues ?
Fix'n it is offline   Reply With Quote
Old 12-22-2013, 05:56 PM   #2
Rewards Points: 154
If you aren't getting ice dams why do you want to do it?
Ice dams indicate a roof ventilation problem. If your neighbors are getting them it means their roofs are poorly ventilated. If you're not getting them this means your roof is well ventilated and you should be OK. If the snow stays on your roof until temperatures warm up enough to melt it naturally you shouldn't have anything to worry about. Where people run into problems is when there is too much heat escaping from the home. This causes snow on the roof to melt even when ambient temperatures are below freezing, and then re-freeze at the edge of the roof where the temps are lower, forming those ice dams.
You would do better to make sure you have sufficient vents and insulation up there so that its warm outdoor temps that melt the snow rather than heat from your HVAC system.
eharri3 is offline   Reply With Quote
Old 12-22-2013, 06:50 PM   #3
Rewards Points: 236
yeah. i know all that. i was just wondering if putting ice melt on the gutters would hurt anything.
Old 12-22-2013, 07:38 PM   #4
DIY staff
Rewards Points: 7,174
I suppose it could cause some corrosion,but the damage would be minimal----
I've done it--and also poured trails on top of ice dams in order to melt a trough through the ice so the roof would drain----
The damage to the interior of a house plagued with ice dams sometimes calls for strong medicine------better to risk roof and gutter damage than let the water get into the ceilings,walls and windows---
Old 12-22-2013, 08:19 PM   #5
Rewards Points: 236
yeah, thats what i was thinkin.
The Following User Says Thank You to Fix'n it For This Useful Post:
oh'mike (12-22-2013)
Old 12-22-2013, 08:19 PM   #6
Gymschu's Avatar
Rewards Points: 834
Usually with the kind of ice build up you are speaking of, ice melters, heated gutter systems, etc. are not effective when it gets that bad.
Gymschu is online now   Reply With Quote
Old 12-22-2013, 08:36 PM   #7
Rewards Points: 236
in the case of my neighbor. it would be necessary to keep at it. 1 application would do almost nothing.
in my case. the last 2 years are sure to be the only years of this house that have seen snow stay on the roof.
Gymschu (12-22-2013)
Old 12-22-2013, 08:37 PM   #8
DIY staff
we have a slew of 1950s cape cod houses---no soffit venting---undersized roof rafters and little if any insulation---those ice up very badly---what a mess inside when that happens.
Old 12-22-2013, 11:45 PM   #9
Website Owner
I would not base your house/gutter on your neighbors. Like comparing cars when both running. Either can break anytime. I have been in the gutter and gutter protection business for awhile. Point blank, whether you are see the effect now or not, Ice dams cause long term damage to the gutter, facia board, and roof, etc. Plus, Icicles form on heavy walk ways. This is dangerous as well. I would lay your own heat cable in your gutter, that can heat up dry stuff in the future and cause issues. I would at least get a free estimate for a heated gutter guard. This protects your gutters and keeps debris out year long.
F.G.G.E. is offline   Reply With Quote
Are you ready for SNOW & ICE ? Roofmaster417 Roofing/Siding 15 10-09-2011 09:25 AM
Heating wire to melt driveway snow konsole Electrical 3 01-23-2011 09:11 PM
Leaking Gutters fripster Roofing/Siding 5 02-13-2010 08:25 PM
Water in Basement during snow melt gruvn Building & Construction 3 05-27-2009 08:13 AM
snow removing gutters from house jerry44 Roofing/Siding 3 12-28-2008 11:50 PM
